Now i tested a token with ALL permissions. Nothing changed. Im pretty sure the problem is based on wrong CORS settings. So thats the reason why i asked about a sample nginx CORS setting file.
@thorsten Im not sure, but if support.zammad.com is running local/intern, its the same konfiguration as mine: i have a ubuntu virtual box running. zammad runs on localhost and i try to connect from local also with a python simpleHTTP Server. I think that setup should work, or im wrong?
Here is my zammad.conf (One version of “thousends” i have tried). No more ideas now…
upstream zammad-railsserver {
server 127.0.0.1:3000;
upstream zammad-websocket {
server 127.0.0.1:6042;
server {
listen 80;
server_name localhost;
root /opt/zammad/public;
client_max_body_size 50M;
expires max;
add_header 'Access-Control-Allow-Origin' *;
add_header 'Access-Control-Allow-Credentials' 'true';
add_header 'Access-Control-Allow-Methods' 'GET';
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
location / {
proxy_read_timeout 300;
gzip on;
gzip_proxied any;
Hey,
sorry but we currently experience quite some support volume on the commercial site.
The community is free, which limits us and our time greatly.
Again: I still think thorsten did his requests on the local developer console which doesn’t need further CORS settings. But @anon29869905 might bring light into the dark here.
Sorry, I did not want to stress you
Then i’m wrong…I thought the issue is caused by the “pre-flight” of the browser. And this IMO has to be handled by the nginx configuration.
PS: Heres the browser output. Browser “asked” with OPTIONS instead of GET.
Zammad will answer with 404 error, as we do not support OPTIONS within that API-Route you’re using.
We can’t change that, that’s nothing we can help you with.
Sure, i know that.
Thats nothing i demand. I dont say its a zammad bug. For me its just interesting why my .js is running on @anon29869905 system. So its not a script issue. Some research told me that the OPTION call causes when the browser made his preflight check . That handling of the preflight IMO is a server configuration. When my script is running on your system , and the setup is almost equal → my local server zammad config is wrong and your setup fine. All i asked for was a sample config of your nginx. YOU dont have to change Zammad
Hi @Rolandrevolvermann - my time currently very limited. However, I don’t want to let you in the dark. You can find the file that is responsible for setting the headers here: zammad/app/controllers/application_controller/sets_headers.rb at 9503ff20cefcfc39cb451562d7ec4fd440198564 · zammad/zammad · GitHub
I assume you need to change that in your setup as well.
Regarding my test result: I was totally out of scope and ran it on the same domain (so exactly not your use case). However, I don’t have the time to setup a testing env so I can’t provide anything else valuable at the current time. Good luck
