30+ second delay when customer creates ticket
Updated javascript to also work when the Agent raises a ticket on behalf of a customer;
(function() {
    console.log("Zammad Interceptor v9 (Agent UI + Payload Scraper) loaded.");
    let checkJquery = setInterval(function() {
        if (window.jQuery) {
            clearInterval(checkJquery);
            window.jQuery.ajaxPrefilter(function(options, originalOptions, jqXHR) {
                if (options.url && options.url.indexOf('external_data_source') !== -1) {
                    try {
                        let smuggledPrefix = "";
                        // --- 1. AGENT VIEW: Check Customer Information Sidebar ---
                        let agentCustomerEmail = "";
                        document.querySelectorAll('.sidebar-content .sidebar-block').forEach(block => {
                            let label = block.querySelector('label');
                            if (label && label.innerText.trim() === 'Email') {
                                // Extract the raw text nodes inside the block (ignoring the label itself)
                                let textNodes = Array.from(block.childNodes).filter(node => node.nodeType === Node.TEXT_NODE);
                                let emailText = textNodes.map(n => n.nodeValue.trim()).join('');
                                if (emailText.includes('@swale.at')) {
                                    agentCustomerEmail = emailText;
                        if (agentCustomerEmail) {
                            // Smuggle the customer's username!
                            smuggledPrefix = "USER:" + agentCustomerEmail.split('@')[0];
                        // --- 2. CUSTOMER VIEW: Check Org Dropdown ---
                        else {
                            const orgInput = document.querySelector('div[data-attribute-name="organization_id"] input.searchableSelect-main');
                            let currentOrg = orgInput ? (orgInput.getAttribute('title') || orgInput.value || "").trim() : "";
                            if (currentOrg) {
                                smuggledPrefix = "ORG:" + currentOrg;
                            // --- 3. CUSTOMER VIEW: Check Profile Avatar ---
                            else {
                                const profileAvatar = document.querySelector('a[href="#current_user"]');
                                if (profileAvatar) {
                                    let email = profileAvatar.getAttribute('title') || "";
                                    if (email && email.includes('@swale.at')) {
                                        smuggledPrefix = "USER:" + email.split('@')[0];
                        // --- 4. Inject into the jQuery Data Payload ---
                        if (smuggledPrefix) {
                            if (options.data && typeof options.data === 'string') {
                                let params = new URLSearchParams(options.data);
                                let currentQuery = params.get('query') || '';
                                if (!currentQuery.includes('||')) {
                                    params.set('query', smuggledPrefix + '||' + currentQuery);
                                    options.data = params.toString();
                                    console.log("Interceptor: Smuggled perfectly ->", options.data);
                    } catch (e) {
                        console.error("Interceptor Error:", e);
    }, 100);
Delay does not exist in new Desktop version - I was unaware that we could test this. Clearly this is a big with the current web interface.
Is there a setting to make the desktop interface the default for the rest of our testing?
No there is not. The new desktop view is still in alpha and might have bugs / quirks that might slow down or even disrupt your productive work. You shouldn’t use it, unless you’re 100% aware.
Just spoke to sales regarding paid support plans, and raised this issue. New desktop version now delayed until 2027…
