While I’m trying to run the application program from the other thread, I enabled the debug log for a while and found the following:
I, [2024-07-01T15:34:33.444554#48972-149480] INFO -- : Parameters: {"limit"=>"50", "_"=>"1719840542534", "facility"=>"ldap"}
D, [2024-07-01T15:34:33.456166#48972-149480] DEBUG -- : HttpLog Load (0.2ms) SELECT "http_logs".* FROM "http_logs" WHERE "http_logs"."facility" = $1 ORDER BY "http_logs"."created_at" DESC LIMIT $2 [["facility", "ldap"], ["LIMIT", 50]]
I, [2024-07-01T15:34:35.910093#48972-149540] INFO -- : Started GET "/api/v1/integration/ldap/job_start?_=1719840542535" for 155.185.3.51 at 2024-07-01 15:34:35 +0200
I, [2024-07-01T15:34:35.914167#48972-149540] INFO -- : Processing by Integration::LdapController#job_start_index as JSON
D, [2024-07-01T15:34:35.920847#48972-149540] DEBUG -- : Permission Load (0.1ms) SELECT "permissions".* FROM "permissions" WHERE "permissions"."name" = $1 LIMIT $2 [["name", "admin.integration.ldap"], ["LIMIT", 1]]
D, [2024-07-01T15:34:35.922076#48972-149540] DEBUG -- : Permission Exists? (0.6ms) SELECT 1 AS one FROM "permissions" INNER JOIN "permissions_roles" ON "permissions"."id" = "permissions_roles"."permission_id" INNER JOIN "roles" ON "permissions_roles"."role_id" = "roles"."id" INNER JOIN "roles_users" ON "roles"."id" = "roles_users"."role_id" WHERE "roles_users"."user_id" = $1 AND "roles"."active" = $2 AND "permissions"."active" = $3 AND "permissions"."name" IN ($4, $5, $6) LIMIT $7 [["user_id", 3], ["active", true], ["active", true], ["name", "admin"], ["name", "admin.integration"], ["name", "admin.integration.ldap"], ["LIMIT", 1]]
D, [2024-07-01T15:34:35.924581#48972-149540] DEBUG -- : ImportJob Load (0.1ms) SELECT "import_jobs".* FROM "import_jobs" WHERE "import_jobs"."name" = $1 AND "import_jobs"."dry_run" = $2 AND "import_jobs"."finished_at" IS NULL ORDER BY "import_jobs"."started_at" DESC, "import_jobs"."id" DESC LIMIT $3 [["name", "Import::Ldap"], ["dry_run", false], ["LIMIT", 1]]
Apparently, if I get it right, it is blaming about a missing permission, but I’m using the administrator account, so what am I really missing? The documentation does not talk about any particular permission needed before the integration is configured.
