- Used Zammad version: 6.3
- Operating system: Win 10
- Browser + version: MSEdge Version 124.0.2478.97
Whenever i create a new channel the destination group is already set to the group which was created first.
This is a problem cause as soon as zammad is then connected to ms365 it will start importing into the wrong group and also the wrong triggers run.
Am I missing something or is this expected behaviour and i need to disable all triggers first and then manually sort the created tickets to a different group?
