Title: Excel report column orders reordering
When adding ticket object attributes, the order of columns in the excel report in unreliable -
We invested time to build excel reports based on some attributes. Adding more attributes should not change the order (new columns should be added at the end of excel report, or we should be able to choose the order) otherwise formulas will break. -
The order in excel report is neither based on ticket object attribute creation order nor creation date, field name or display attribute. The position value would be a logical choice but it does not work either. -
We would like new ticket object attributes to appear after old ticket object attributes or we would like to choose the order in the excel export.
We could fix this by slightly changing the code at zammad/lib/excel_sheet/ticket.rb at 93f4da17112d495862bdd8ba04fcf3e4362bf88e · zammad/zammad · GitHub
Current code :
ObjectManager::Attribute
.where(
active: true,
to_create: false,
object_lookup: ObjectLookup.lookup(name: 'Ticket')
.where.not(
.where.not(
display: header.pluck(:display)
.pluck_as_hash(:name, :display, :data_type, :data_option)
.each { |elem| elem[:width] = 20 }
.then { |objects| header.concat(objects) }
Fixed code (we added the “.order(:position)” line):
.where(
active: true,
to_create: false,
.where.not(
.where.not(
.order(:position)
Your Zammad environment:
- Average concurrent agent count: 50
- Average tickets a day: 100
- What roles/people are involved: Buyers, Hotline
Thank you and have fun.
