How do I install Zammad with MySQL instead of PostgreSQL?
Can you be more clear? In which version of linux are you going to install? And how are you going to install zammad? Via DEB/RPM or via source?
Hi - I’ve managed to sort out the issue. Basically connecting to the PostgreSQL db wasn’t straight forward so I wanted to move to a MySQL db.
I’ve sorted out what I needed now however and the connection to the PostgreSQL db works.
Thanks for taking the time to reply to me.
