Zammad v6 LDAP Sync
  • Used Zammad version: 6
  • Used Zammad installation type: (source, package, docker-compose, …) packege
  • Operating system: Centos 8
  • Browser + version: Chrome v115
  • run on zammad console Scheduler.find_by(name: ‘Import Jobs’).update!(period: 1.day) to modify ldap sync process
irb(main):005:0> Scheduler.find_by(name: ‘Import Jobs’).update!(period: 1.day)
(irb):5:in <main>': undefined method update!’ for nil:NilClass (NoMethodError)
irb(main):006:0>
undefin method update!
run on zammad v6 rails console .update! method
Hi @gelt00. Could you please describe your original issue in more detail?
I am trying to modify the execution interval of the ldap Sync task, from 1 hour to 24 hours, but the command in one of the posts does not work with version 6.0.0 of zammad
Also, trying to modify the .rb and compile again doesn’t seem to work.
Any rails console command to increase Interval time?
Maybe this is kind of helpful.
thanks a lot
Just to be sure: This affects all import jobs, not only LDAP.
but on mail fetch channel too ? or only Exchange Import
I mean which are these all import jobs
It affects Import::Ldap and Import::Exchange.
