The feature: Using Zammad with SendGrid for outbound email using Sendgrid transnational email templates. Would be awesome if there was way in the application (plugin?) to use the API.
Still, I’m looking for advice on connecting Zammad with Sendgrid. My thought is to connect Sendmail to SendGrid. Part of the issue is to trigger the transnational email templates you need to add an X-SMTPAPI Header before sending to Sendgrid.
Any other thoughts or advice are appreciated .
Thanks,
