deusyv
1
zammad run rails assets:precompile
Yarn executable was not detected in the system.
Download Yarn at https://yarnpkg.com/en/docs/install
rails aborted!
Uglifier::Error: Unexpected token name «or», expected punc «)». To use ES6 syntax, harmony mode must be enabled with Uglifier.new(:harmony => true).
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/uglifier-4.1.20/lib/uglifier.rb:234:in `parse_result'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/uglifier-4.1.20/lib/uglifier.rb:216:in `run_uglifyjs'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/uglifier-4.1.20/lib/uglifier.rb:168:in `compile'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/uglifier_compressor.rb:53:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/uglifier_compressor.rb:28:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:75:in `call_processor'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:57:in `block in call_processors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `reverse_each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `call_processors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:134:in `load_from_unloaded'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:60:in `block in load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:44:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:20:in `block in initialize'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:47:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:66:in `find_asset'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:73:in `find_all_linked_assets'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:142:in `block in find'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/legacy.rb:114:in `block (2 levels) in logical_paths'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/path_utils.rb:228:in `block in stat_tree'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/path_utils.rb:212:in `block in stat_directory'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/path_utils.rb:209:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/path_utils.rb:209:in `stat_directory'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/path_utils.rb:227:in `stat_tree'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/legacy.rb:105:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/legacy.rb:105:in `block in logical_paths'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/legacy.rb:104:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/legacy.rb:104:in `logical_paths'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:140:in `find'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:186:in `compile'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/task.rb:68:in `block (3 levels) in define'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/rake/sprocketstask.rb:147:in `with_logger'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/task.rb:67:in `block (2 levels) in define'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/commands/rake/rake_command.rb:23:in `block in perform'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/commands/rake/rake_command.rb:20:in `perform'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/command.rb:48:in `invoke'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.4/lib/rails/commands.rb:18:in `<main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies.rb:291:in `block in require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies.rb:257:in `load_dependency'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.4/lib/active_support/dependencies.rb:291:in `require'
/opt/zammad/bin/rails:9:in `<main>'
Tasks: TOP => assets:precompile
Is this a vanilla Zammad installation or did you change / add code…?
system
Closed
3
