Hello everyone, we are faced with the problem of restoring from backup (zammad in docker)
Unfortunately the described method is at
does not work for us.
I tried to manually make changes to the database and restore files. Everything was restored, but here we were faced with another problem: users are not displayed in the web interface, although they are present in the database table.
- Used Zammad version: -4.0.0-7
- Used Zammad installation type: (source, package, docker-compose, …)
- Operating system: Ubuntu 18.4
- Browser + version: Opera 82.0.4227.43
Restore OK
error in path config
/opt/zammad/contrib/backup/config.dist
cat: can’t open ‘/opt/zammad/contrib/backup/config.dist’: No such file or directory
etc
Stopping services
# docker-compose stop zammad-nginx zammad-websocket zammad-railsserver zammad-memcached zammad-elasticsearch zammad-scheduler
Drop database content
# docker-compose exec zammad-postgresql su -c 'dropdb zammad_production' - postgres
Start Scheduler again (to recreate empty db)
# docker-compose start zammad-scheduler
Recreate empty database
# docker-compose exec zammad-scheduler bundle exec rake db:create
(Preparing) Restore
# docker-compose exec zammad-postgresql /bin/sh
$ cp /opt/zammad/contrib/backup/config.dist /opt/zammad/contrib/backup/config && \
sed -i s/zammad_backup/zammad/g /opt/zammad/contrib/backup/config && \
ln -s /usr/local/bin/psql /usr/bin/ && \
/opt/zammad/contrib/backup/zammad_restore.sh
Restart whole compose stack
# docker-compose stop; docker-compose start && docker-compose logs -f
How did you manage to do:
Stopping services
docker-compose exec zammad-postgresql bash
su - postgres
psql -U zammad
SELECT datname,datistemplate,datallowconn,datconnlimit FROM pg_database;
ALTER DATABASE zammad_production;
DROP DATABASE zammad_production;
\q
- Copy bkp DB in
/var/lib/docker/volumes/zammad-docker-compose_postgresql-data/_data/
su - postgres
psql -U zammad
\connect zammad_production;
\i /var/lib/postgresql/data/20210513120754_zammad_db.psql
select table_name, column_name from information_schema.columns where table_schema=‘public’;
\q
- Copy bkp Files in
/var/lib/docker/volumes/zammad-docker-compose_zammad-data/_data/
docker-compose exec zammad-backup bash
cd /
tar -xvzf /opt/zammad/20210513120754_zammad_files.tar.gz
- docker-compose stop; docker-compose start && docker-compose logs -f
But this way has a problem, as mentioned above:
users are not displayed:
http://1.2.3.4/#manage/users
