I had some issues with elasticsearch that it is wat not connecting tot zammad so i reinstalled this was partaly succefull now if check the search option in elasticseach this still gives me some weird errors
root@zammad:/var/log/elasticsearch# curl http://localhost:9200/zammad_production_ticket/_search
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [zammad_production_ticket]","resource.type":"index_or_alias","resource.id":"zammad_production_ticket","index_uuid":"_na_","index":"zammad_production_ticket"}],"type":"index_not_found_exception","reason":"no such index [zammad_production_ticket]","resource.type":"index_or_alias","resource.id":"zammad_production_ticket","index_uuid":"_na_","index":"zammad_production_ticket"},"status":404}root@zammad:/var/log/elasticsearch#
so i tought lets rebuild this but this gives me also some errors bellow you can consult the error can someone help me out?
- Used Zammad version: 5.2x
- Used Zammad installation type: Debian Package
- Operating system: Debian
- Browser + version: Chrome
- succesfull reindex
root@zammad:/var/log/elasticsearch# zammad run rake searchindex:rebuild --trace
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
rake aborted!
NoMethodError: undefined method `version_supported?' for SearchIndexBackend:Class
/opt/zammad/lib/tasks/search_index_es.rake:69:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:243:in `block in invoke_prerequisites'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `each'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `invoke_prerequisites'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.0.0/bin/rake:25:in `load'
/opt/zammad/vendor/bundle/ruby/3.0.0/bin/rake:25:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli.rb:483:in `exec'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli.rb:31:in `dispatch'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/cli.rb:25:in `start'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/exe/bundle:48:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/3.0.0/gems/bundler-2.3.10/exe/bundle:36:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
Tasks: TOP => searchindex:rebuild => searchindex:version_supported
- zammad run rake searchindex:rebuild --trace
