Hi, i see in my users options that appear me this user “auto-”
When i see the configuraion all is right name and lastname, why this? and how can change this for a username normal.
Are you using LDAP and/or Exchange synchronization?
I have created the users manually, but this users i dont know how they been created.
Login is auto created if you don’t provide a mail address.
Hello!
I installed Zammad from scratch and added a few users manually:
So far, everything looks OK and no auto-XXX are generated.
Check that you do not have enabled any integration, like LDAP or Exchange…
HTH
Hi @MrGeneration my system not allow that customer creare self users, i disable this option. @rsysadmin i never enable the option of integrate with LDAP here is empty configuration. The last activity that i make Is a update and upgrade of the system.
Still your agents are allowed to add new customers during ticket creation.
You can’t disable this behavior because it’s a core function.
