Used Zammad version: 3.6
Used Zammad installation source: package
Operating system: CentOS
Expected behavior: Reduce CPU/RAM usage after enable OPcache
Hello
I have small CPU resource on my zammad VM, Interest to know did anybody enabled OPcache on Zammad?
Can i expect reduce CPU usage after enabling OPcache on zammad machine?
OPcache is a PHP caching mechanism, isn’t it?
Might be missing a point, but Zammad is written in Ruby and thus this won’t help you. ;-(
I guess reduction of your CPU usuage is unlikely depending on your configuration.
If your host does not meet the system requirements, I’m afraid, there’s not really much we can do about that.
Yes, OPcache is a PHP caching mechanism you are right definitely!
Thanks
