Zammad Version = 3.3.0
Zammad Installation Source : DEB UBUNTU works but can’t set Modsecurity 3.0 OWASP on NGINX
Zammad Installation Source : doing Modsecurity 3.0 OWASP on NGINX with Nginx Instructions no errors but unsuccessful
- Used Zammad version: 3.3.0
- Used Zammad installation source: (source, package, …) try both
- Operating system: UBUNTU 18.04 LTS
- Browser + version: Chrome 81.0.4044.138 (Build oficial) (64 bits)
- SSL from Certbot
Hi
Try to secure Nginx with ModSecurity 3.0 but was unsuccessful to compile it, was done in two ways:}
1 Compile with Nginx custom install within Zammad Package, no chance to compile it, search on Nginx and recommend to install according to their instructions.
2 Compile with Nginx install instructions and was successful but try to install the Zammad package over this compiled ModSecurity-Nginx, the package install and respect the Nginx installed, but at the end does not start to setup.
Install from zero using Zammad Package works fine without ModSecurity, SSL installed everything fine, no complains.
Described on point 1 and 2.
Compile Nginx with ModSecurity using Zammad Package, which is the assured path to work Zammad.
Hope this explain in good terms the situation.
Best Regards
