Zammad Install | Rocky 9 | Postgresql issues
  • Used Zammad version: 7.0
  • Operating system: Rocky 9
  • Browser + version:
No DB issues and full deployment
# Updating translations...
/opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in 'PG::Connection#exec': PG::ForeignKeyViolation: ERROR:  insert or update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" (ActiveRecord::InvalidForeignKey)
DETAIL:  Key (created_by_id)=(1) is not present in table "users".
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in 'ActiveRecord::ConnectionAdapters::PostgreSQL::DatabaseStatements#perform_query'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:556:in 'block (2 levels) in ActiveRecord::ConnectionAdapters::DatabaseStatements#raw_execute'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1017:in 'block in ActiveRecord::ConnectionAdapters::AbstractAdapter#with_raw_connection'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/concurrency/null_lock.rb:9:in 'ActiveSupport::Concurrency::NullLock#synchronize'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:986:in 'ActiveRecord::ConnectionAdapters::AbstractAdapter#with_raw_connection'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:555:in 'block in ActiveRecord::ConnectionAdapters::DatabaseStatements#raw_execute'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/notifications/instrumenter.rb:58:in 'ActiveSupport::Notifications::Instrumenter#instrument'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1137:in 'ActiveRecord::ConnectionAdapters::AbstractAdapter#log'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:554:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#raw_execute'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:591:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#internal_execute'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:547:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#internal_exec_query'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:693:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#select'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:73:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#select_all'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:259:in 'block in ActiveRecord::ConnectionAdapters::QueryCache#select_all'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:297:in 'block (2 levels) in ActiveRecord::ConnectionAdapters::QueryCache#cache_sql'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:80:in 'ActiveRecord::ConnectionAdapters::QueryCache::Store#compute_if_absent'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:295:in 'block in ActiveRecord::ConnectionAdapters::QueryCache#cache_sql'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:294:in 'ActiveRecord::ConnectionAdapters::QueryCache#cache_sql'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/query_cache.rb:259:in 'ActiveRecord::ConnectionAdapters::QueryCache#select_all'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:102:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#select_rows'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:96:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#select_values'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/adapters/postgresql_adapter.rb:33:in 'ActiveRecord::Import::PostgreSQLAdapter#insert_many'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:835:in 'block in ActiveRecord::Base.import_without_validations_or_callbacks'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:831:in 'Array#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:831:in 'Enumerable#each_slice'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:831:in 'ActiveRecord::Base.import_without_validations_or_callbacks'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:771:in 'ActiveRecord::Base.import_with_validations'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:702:in 'ActiveRecord::Base.import_helper'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-import-2.2.0/lib/activerecord-import/import.rb:536:in 'ActiveRecord::Base.bulk_import'
	from /opt/zammad/app/models/translation/synchronizes_from_po.rb:107:in 'Translation::SynchronizesFromPo::ClassMethods#sync_locale_from_po'
	from /opt/zammad/app/models/translation/synchronizes_from_po.rb:54:in 'block (2 levels) in Translation::SynchronizesFromPo::ClassMethods#sync'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/transaction.rb:626:in 'block in ActiveRecord::ConnectionAdapters::TransactionManager#within_new_transaction'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/transaction.rb:623:in 'ActiveRecord::ConnectionAdapters::TransactionManager#within_new_transaction'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:367:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#within_new_transaction'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:359:in 'ActiveRecord::ConnectionAdapters::DatabaseStatements#transaction'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/transactions.rb:233:in 'block in ActiveRecord::Transactions::ClassMethods#transaction'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:422:in 'ActiveRecord::ConnectionAdapters::ConnectionPool#with_connection'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_handling.rb:312:in 'ActiveRecord::ConnectionHandling#with_connection'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/transactions.rb:232:in 'ActiveRecord::Transactions::ClassMethods#transaction'
	from /opt/zammad/app/models/translation/synchronizes_from_po.rb:53:in 'block in Translation::SynchronizesFromPo::ClassMethods#sync'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/relation/delegation.rb:101:in 'Array#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/relation/delegation.rb:101:in 'ActiveRecord::Delegation#each'
	from /opt/zammad/app/models/translation/synchronizes_from_po.rb:52:in 'Translation::SynchronizesFromPo::ClassMethods#sync'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:49:in '<main>'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:49:in 'Kernel#eval'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:49:in 'block in Rails::Command::RunnerCommand#perform'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.4/lib/active_support/execution_wrapper.rb:91:in 'ActiveSupport::ExecutionWrapper.wrap'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:70:in 'Rails::Command::RunnerCommand#conditional_executor'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:48:in 'Rails::Command::RunnerCommand#perform'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/thor-1.5.0/lib/thor/command.rb:28:in 'Thor::Command#run'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/thor-1.5.0/lib/thor/invocation.rb:127:in 'Thor::Invocation#invoke_command'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command/base.rb:178:in 'Rails::Command::Base#invoke_command'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/thor-1.5.0/lib/thor.rb:538:in 'Thor.dispatch'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command/base.rb:73:in 'Rails::Command::Base.perform'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command.rb:65:in 'block in Rails::Command.invoke'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command.rb:143:in 'Rails::Command.with_argv'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command.rb:63:in 'Rails::Command.invoke'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands.rb:18:in '<main>'
	from /opt/zammad/vendor/ruby-3.4.8/lib/ruby/3.4.0/bundled_gems.rb:82:in 'Kernel.require'
	from /opt/zammad/vendor/ruby-3.4.8/lib/ruby/3.4.0/bundled_gems.rb:82:in 'block (2 levels) in Kernel#replace_require'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/bootsnap-1.22.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:33:in 'Kernel#require'
	from /opt/zammad/bin/rails:4:in '<main>'
/opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in 'PG::Connection#exec': ERROR:  insert or update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" (PG::ForeignKeyViolation)
# No custom packages detected...
/opt/zammad/vendor/ruby-3.4.8/lib/ruby/3.4.0/bundled_gems.rb:82:in 'Kernel.require': Interrupt
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/core_ext/kernel.rb:34:in 'Kernel#require'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/activejob-8.0.4/lib/active_job/base.rb:3:in '<main>'
	from /opt/zammad/app/jobs/application_job.rb:3:in '<main>'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/core_ext/kernel.rb:26:in 'Kernel#require'
	from /opt/zammad/app/jobs/active_job_lock_cleanup_job.rb:3:in '<main>'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/cref.rb:62:in 'Module#const_get'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/cref.rb:62:in 'Zeitwerk::Cref#get'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:173:in 'block in Zeitwerk::Loader::EagerLoad#actual_eager_load_dir'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/helpers.rb:47:in 'block in Zeitwerk::Loader::Helpers#ls'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/helpers.rb:25:in 'Array#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/helpers.rb:25:in 'Zeitwerk::Loader::Helpers#ls'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:168:in 'Zeitwerk::Loader::EagerLoad#actual_eager_load_dir'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:17:in 'block (2 levels) in Zeitwerk::Loader::EagerLoad#eager_load'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:16:in 'Hash#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:16:in 'block in Zeitwerk::Loader::EagerLoad#eager_load'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:10:in 'Thread::Mutex#synchronize'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader/eager_load.rb:10:in 'Zeitwerk::Loader::EagerLoad#eager_load'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader.rb:431:in 'block in Zeitwerk::Loader.eager_load_all'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/registry/loaders.rb:10:in 'Array#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/registry/loaders.rb:10:in 'Zeitwerk::Registry::Loaders#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/zeitwerk-2.7.4/lib/zeitwerk/loader.rb:429:in 'Zeitwerk::Loader.eager_load_all'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/application/finisher.rb:79:in 'block in <module:Finisher>'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:32:in 'BasicObject#instance_exec'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:32:in 'Rails::Initializable::Initializer#run'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:61:in 'block in Rails::Initializable#run_initializers'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:231:in 'block in TSort.tsort_each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:353:in 'block (2 levels) in TSort.each_strongly_connected_component'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:434:in 'TSort.each_strongly_connected_component_from'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:352:in 'block in TSort.each_strongly_connected_component'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'Rails::Initializable::Collection#each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'Method#call'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:350:in 'TSort.each_strongly_connected_component'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:229:in 'TSort.tsort_each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/tsort-0.2.0/lib/tsort.rb:208:in 'TSort#tsort_each'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/initializable.rb:60:in 'Rails::Initializable#run_initializers'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/application.rb:444:in 'Rails::Application#initialize!'
	from /opt/zammad/config/environment.rb:7:in '<main>'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/application.rb:420:in 'Rails::Application#require_environment!'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/command/actions.rb:20:in 'Rails::Command::Actions#boot_application!'
	from /opt/zammad/vendor/bundle/ruby/3.4.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:30:in 'Rails::Command::RunnerCommand#perform'
Running the below after installing a elasticsearch and postgres and installing the repo.
dnf install zammad
What version of postgres did you install?
Postgres is running 13.23 version
Can you try to install postgresql server (and ensure it’s started), before installing Zammad?
It’s just a feeling, but my bet is that the provided error message isn’t the first one (it might be a lot output so).
Because usually you’d also see a ton of migration messages and those should have failed too (at least in my guess).
Thanks for the details, i actually did that. I installed postgres and elasticsearch manually first because the rpm package just kept failing…
Steps taken after the “dnf install zammad” didnt work is
sudo -u postgres psql -v ON_ERROR_STOP=1 <<SQL
-- terminate sessions
SELECT pg_terminate_backend(pid) FROM pg_stat_activity WHERE datname='zammad';
DROP DATABASE IF EXISTS zammad;
DROP ROLE IF EXISTS zammad;
CREATE ROLE zammad LOGIN PASSWORD '${ZPASS}';
CREATE DATABASE zammad OWNER zammad ENCODING 'UTF8';
SQL
updated the database config file with the new password
sudo /opt/zammad/contrib/packager.io/postinstall.sh
but all i get are errors during the postinstall.
# Enforcing Redis...
# Creating Redis bootstart
# Starting Redis server
# Redis server is running.
# (Re)creating init scripts
Nothing to do.
Nothing to do.
Nothing to do.
# Enabling Zammad on boot
# Stopping Zammad
# Clear cache...
/opt/zammad/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in 'PG::Connection#exec': PG::UndefinedTable: ERROR:  relation "settings" does not exist (ActiveRecord::StatementInvalid)
LINE 10:  WHERE a.attrelid = '"settings"'::regclass
connection_adapters/postgresql/database_statements.rb:167:in 'PG::Connection#exec': ERROR:  relation "settings" does not exist (PG::UndefinedTable)
== 20120101000001 CreateBase: migrating =======================================
-- create_table(:sessions, {id: :integer})
   -> 0.0239s
-- Nevermind, no es_url is set, leaving Elasticsearch untouched ...!
-- The above is all right if you don't want to use Elasticsearch (locally) - if this is not intended, consult https://docs.zammad.org !
/opt/zammad/app/models/setting.rb:45:in 'Setting.set': Can't find config setting 'es_url' (RuntimeError)
# Enforcing 0600 on database.yml ...
# Starting Zammad
# Restarting webserver nginx - please check if all required modules are enabled in case webserver fails to start.
I’m out of ideas, sorry. This seems to lay deeper and I don’t have enough free time to hike down the Rocky road (sorry).
