Hi, i have a enable the option of chatbot on telegram and all work fine, i need know how can close the attention? the autoresponse work but then i change the state to close not send the notificaction. This is normal or how can close a case?
Zammad has no trigger action for sending telegram messages to the user.
So what you’re trying to accomplish is not possible.
