- Used Zammad version: 3.6.0-20
- Used Zammad installation source: (source, package, …) - Docker
- Operating system: K8s
- Zammad sync the data
- Jobs failing
Zammad it’s have a lot of problems with the Delayed Jobs, and stop, running on a Kubernetes cluster:
I, [2021-01-22T09:57:40.203889 #1-47018330954100] INFO – : Setting.set(‘models_searchable’, [“Organization”, “Chat::Session”, “KnowledgeBase::Answer::Translation”, “Ticket”, “User”])
I, [2021-01-22T09:57:41.459690 #1-47018330954100] INFO – : Scheduler started.
I, [2021-01-22T09:57:41.481304 #1-47018330954100] INFO – : Cleanup of left over locked delayed jobs 2021-01-22 12:57:41 UTC started.
I, [2021-01-22T09:57:41.548556 #1-47018330954100] INFO – : Checking left over delayed job #<Delayed::Backend::ActiveRecord::Job id: 2776434, priority: 200, attempts: 0, handler: “— !ruby/object:ActiveJob::QueueAdapters::Delayed…”, last_error: nil, run_at: “2021-01-21 15:58:27”, locked_at: “2021-01-22 12:46:15”, failed_at: nil, locked_by: “host:saas-zammad-local-0 pid:1”, queue: “default”, created_at: “2021-01-21 15:58:27”, updated_at: “2021-01-21 15:58:27”> started.
bundler: failed to load command: script/scheduler.rb (script/scheduler.rb)
ActiveJob::DeserializationError: Error while trying to deserialize arguments: Couldn’t find Ticket with ‘id’=24771
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation/finder_methods.rb:346:in `raise_record_not_found_exception!’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation/finder_methods.rb:456:in `find_one’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation/finder_methods.rb:435:in `find_with_ids’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation/finder_methods.rb:69:in `find’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/querying.rb:5:in `find’
/usr/local/bundle/gems/composite_primary_keys-11.2.0/lib/composite_primary_keys/core.rb:24:in `find’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:130:in `locate’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:155:in `block in locate’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:165:in `block in unscoped’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/scoping/default.rb:34:in `block in unscoped’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation.rb:281:in `scoping’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/scoping/default.rb:34:in `unscoped’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:165:in `unscoped’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:155:in `locate’
/usr/local/bundle/gems/globalid-0.4.2/lib/global_id/locator.rb:17:in `locate’
/usr/local/bundle/gems/activejob-5.2.4.4/lib/active_job/arguments.rb:101:in `deserialize_global_id’
/usr/local/bundle/gems/activejob-5.2.4.4/lib/active_job/arguments.rb:87:in `deserialize_argument’
/usr/local/bundle/gems/activejob-5.2.4.4/lib/active_job/arguments.rb:41:in `block in deserialize’
/usr/local/bundle/gems/activejob-5.2.4.4/lib/active_job/arguments.rb:41:in `map’
/usr/local/bundle/gems/activejob-5.2.4.4/lib/active_job/arguments.rb:41:in `deserialize’
/opt/zammad/config/initializers/delayed_jobs_ensure_active_job_lock_removal.rb:14:in `remove_active_job_lock’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:426:in `block in make_lambda’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:236:in `block in halting_and_conditional’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:517:in `block in invoke_after’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:517:in `each’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:517:in `invoke_after’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:133:in `run_callbacks’
/usr/local/bundle/gems/activesupport-5.2.4.4/lib/active_support/callbacks.rb:816:in `_run_destroy_callbacks’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/callbacks.rb:323:in `destroy’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/transactions.rb:305:in `block in destroy’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/database_statements.rb:267:in `block in transaction’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction’
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/connection_adapters/abstract/database_statements.rb:267:in `transaction’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/transactions.rb:212:in `transaction’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/transactions.rb:385:in `with_transaction_returning_status’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/transactions.rb:305:in `destroy’
/opt/zammad/app/models/scheduler.rb:193:in `cleanup_delayed’
/opt/zammad/app/models/scheduler.rb:143:in `block (3 levels) in cleanup_delayed_jobs’
/opt/zammad/lib/mixin/start_finish_logger.rb:7:in `log_start_finish’
/opt/zammad/app/models/scheduler.rb:142:in `block (2 levels) in cleanup_delayed_jobs’
/usr/local/bundle/gems/activerecord-5.2.4.4/lib/active_record/relation/delegation.rb:71:in `each’
/opt/zammad/app/models/scheduler.rb:141:in `block in cleanup_delayed_jobs’
/opt/zammad/app/models/scheduler.rb:139:in `cleanup_delayed_jobs’
/opt/zammad/app/models/scheduler.rb:126:in `cleanup’
/opt/zammad/app/models/scheduler.rb:23:in `threads’
script/scheduler.rb:74:in `block in <top (required)>’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons/application.rb:275:in `block in start_proc’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons/application.rb:284:in `start_proc’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons/application.rb:305:in `start’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons/controller.rb:59:in `run’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons.rb:199:in `block in run_proc’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons/cmdline.rb:121:in `catch_exceptions’
/usr/local/bundle/gems/daemons-1.3.1/lib/daemons.rb:198:in `run_proc’
script/scheduler.rb:54:in `<top (required)>’
I, [2021-01-22T09:57:41.559136 #1-47018330954100] INFO – : script/scheduler.rb stopped.
I don’t if i can change the time of the job to wait for the database commit, i have a big customer, it’s more than 20k tickets by month.
Thanks
