in the mail.log I can see successful logins to imap/dovecot but only sometimes a password mismatch when trying to send Mails by smtp, more often i can’t see any request from zammad:
Jan 6 11:25:33 mx dovecot[3090]: imap-login: Login: user=<support-test@example.de>, method=PLAIN, rip=x.x.x.x, lip=y.y.y.y, mpid=28031, TLS, session=<dW9hSufUnKaod7K8>
Jan 6 11:25:58 mx dovecot[3090]: auth-worker(5470): sql(support-test@example.de,x.x.x.x,<3RHaS+fUpqaod7K8>): Password mismatch
Here the log from zammad when i try to send a mail and i see nothing in the mail.log:
I, [2022-01-07T15:21:00.665753 #18653-173860] INFO -- : Started PUT "/api/v1/taskbar/91" for 185.68.78.141 at 2022-01-07 15:21:00 +0100
I, [2022-01-07T15:21:00.674456 #18653-173860] INFO -- : Processing by TaskbarController#update as JSON
I, [2022-01-07T15:21:00.674691 #18653-173860] INFO -- : Parameters: {"key"=>"TicketCreateScreen-77955", "client_id"=>"123", "callback"=>"TicketCreate", "state"=>{"body"=>"[FILTERED]", "formSenderType"=>"email-out", "form_id"=>"56526200
9", "title"=>"", "customer_id"=>"18", "customer_id_completion"=>"Trude Test <test@hostianer.com>", "cc"=>"", "group_id"=>"", "owner_id"=>"", "state_id"=>"2", "priority_id"=>"2", "tags"=>""}, "params"=>{"id"=>"77955", "shown"=>true}, "prio
"=>15, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2022-01-07T14:20:22.610Z", "id"=>"91"}
I, [2022-01-07T15:21:00.736202 #18653-173860] INFO -- : Completed 200 OK in 61ms (Views: 0.6ms | ActiveRecord: 11.9ms | Allocations: 14539)
I, [2022-01-07T15:21:05.427717 #18653-265240] INFO -- : Started PUT "/api/v1/taskbar/91" for 185.68.78.141 at 2022-01-07 15:21:05 +0100
I, [2022-01-07T15:21:05.435899 #18653-265240] INFO -- : Processing by TaskbarController#update as JSON
I, [2022-01-07T15:21:05.436056 #18653-265240] INFO -- : Parameters: {"key"=>"TicketCreateScreen-77955", "client_id"=>"123", "callback"=>"TicketCreate", "state"=>{"body"=>"[FILTERED]", "formSenderType"=>"email-out", "form_id"=>"56526200
9", "title"=>"Nur ein Test", "customer_id"=>"18", "customer_id_completion"=>"Trude Test <test@hostianer.com>", "cc"=>"", "group_id"=>"", "owner_id"=>"", "state_id"=>"2", "priority_id"=>"2", "tags"=>""}, "params"=>{"id"=>"77955", "shown"=>
true}, "prio"=>15, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2022-01-07T14:20:22.610Z", "id"=>"91"}
I, [2022-01-07T15:21:05.479602 #18653-265240] INFO -- : Completed 200 OK in 43ms (Views: 0.6ms | ActiveRecord: 9.3ms | Allocations: 14670)
I, [2022-01-07T15:21:13.053970 #18653-219360] INFO -- : Started POST "/api/v1/integration/smime" for 185.68.78.141 at 2022-01-07 15:21:13 +0100
I, [2022-01-07T15:21:13.063624 #18653-219360] INFO -- : Processing by Integration::SMIMEController#search as JSON
I, [2022-01-07T15:21:13.063835 #18653-219360] INFO -- : Parameters: {"ticket"=>{"body"=>"[FILTERED]", "formSenderType"=>"email-out", "form_id"=>"565262009", "title"=>"Nur ein Test", "customer_id"=>"18", "customer_id_completion"=>"Trude
Test <test@hostianer.com>", "cc"=>"", "group_id"=>"1", "owner_id"=>"", "state_id"=>"2", "priority_id"=>"2", "tags"=>"", "to"=>"Trude Test <test@hostianer.com>"}, "article"=>{"body"=>"[FILTERED]", "formSenderType"=>"email-out", "form_id"=
>"565262009", "title"=>"Nur ein Test", "customer_id"=>"18", "customer_id_completion"=>"Trude Test <test@hostianer.com>", "cc"=>"", "group_id"=>"1", "owner_id"=>"", "state_id"=>"2", "priority_id"=>"2", "tags"=>"", "to"=>"Trude Test <test@h
ostianer.com>"}}
I, [2022-01-07T15:21:13.096827 #18653-219360] INFO -- : Completed 200 OK in 33ms (Views: 0.3ms | ActiveRecord: 10.7ms | Allocations: 8657)
I, [2022-01-07T15:21:15.118044 #18653-207940] INFO -- : Started PUT "/api/v1/taskbar/91" for 185.68.78.141 at 2022-01-07 15:21:15 +0100
I, [2022-01-07T15:21:15.128070 #18653-207940] INFO -- : Processing by TaskbarController#update as JSON
I, [2022-01-07T15:21:15.128186 #18653-207940] INFO -- : Parameters: {"key"=>"TicketCreateScreen-77955", "client_id"=>"123", "callback"=>"TicketCreate", "state"=>{"body"=>"[FILTERED]", "formSenderType"=>"email-out", "form_id"=>"56526200
9", "title"=>"Nur ein Test", "customer_id"=>"18", "customer_id_completion"=>"Trude Test <test@hostianer.com>", "cc"=>"", "group_id"=>"1", "owner_id"=>"", "state_id"=>"2", "priority_id"=>"2", "tags"=>""}, "params"=>{"id"=>"77955", "shown"=
I, [2022-01-07T15:21:15.184497 #18653-207940] INFO -- : Completed 200 OK in 56ms (Views: 0.6ms | ActiveRecord: 11.1ms | Allocations: 14632)
I, [2022-01-07T15:21:18.036605 #18653-253740] INFO -- : Started POST "/api/v1/tickets" for 185.68.78.141 at 2022-01-07 15:21:18 +0100
I, [2022-01-07T15:21:18.046175 #18653-253740] INFO -- : Processing by TicketsController#create as JSON
I, [2022-01-07T15:21:18.046329 #18653-253740] INFO -- : Parameters: {"title"=>"Nur ein Test", "group_id"=>"1", "owner_id"=>"", "customer_id"=>"18", "state_id"=>"2", "priority_id"=>"2", "article"=>{"from"=>"Users", "to"=>"Trude Test <test@hostianer.com>", "cc"=>"", "body"=>"[FILTERED]", "type_id"=>1, "sender_id"=>1, "form_id"=>"565262009", "content_type"=>"text/html"}, "tags"=>"", "id"=>"c-23"}
I, [2022-01-07T15:21:18.295640 #18653-253740] INFO -- : Completed 201 Created in 249ms (Views: 0.5ms | ActiveRecord: 65.8ms | Allocations: 58129)
I, [2022-01-07T15:21:18.377522 #18653-265240] INFO -- : Started DELETE "/api/v1/taskbar/91" for 185.68.78.141 at 2022-01-07 15:21:18 +0100
I, [2022-01-07T15:21:18.382844 #18653-173860] INFO -- : Started GET "/api/v1/tickets/23?all=true&_=1641462633863" for 185.68.78.141 at 2022-01-07 15:21:18 +0100
I, [2022-01-07T15:21:18.390676 #18653-265240] INFO -- : Processing by TaskbarController#destroy as JSON
I, [2022-01-07T15:21:18.393628 #18653-265240] INFO -- : Parameters: {"id"=>"91"}
I, [2022-01-07T15:21:18.393460 #18653-173860] INFO -- : Processing by TicketsController#show as JSON
I, [2022-01-07T15:21:18.394148 #18653-173860] INFO -- : Parameters: {"all"=>"true", "_"=>"1641462633863", "id"=>"23"}
I, [2022-01-07T15:21:18.506969 #18653-265240] INFO -- : Completed 200 OK in 113ms (Views: 0.3ms | ActiveRecord: 54.5ms | Allocations: 41684)
I, [2022-01-07T15:21:18.537166 #18653-219360] INFO -- : Started POST "/api/v1/taskbar" for 185.68.78.141 at 2022-01-07 15:21:18 +0100
I, [2022-01-07T15:21:18.543449 #18653-219360] INFO -- : Processing by TaskbarController#create as JSON
I, [2022-01-07T15:21:18.543585 #18653-219360] INFO -- : Parameters: {"key"=>"Ticket-23", "client_id"=>123, "callback"=>"TicketZoom", "params"=>{"ticket_id"=>"23", "shown"=>true}, "prio"=>15, "notify"=>false, "active"=>true, "id"=>"c-504"}
