last of the depot
Operating system:
Ubuntu 16.04
First thank you very much for your help.
Since the update from 2.8 to 2.9, zammad is no longer retrieving mails automatically and it’s very slow. The background jobs are always increasing.
I send you the content of the monitoring page
healthy
false
message
" channel is active but not fetched for about 6 hours; channel is active but not fetched for about 6 hours; channel is active but not fetched for about 6 hours; channel is active but not fetched for about 6 hours;unprocessable mails: 1;scheduler may not run (last execution of Chat.cleanup 2 days over) - please contact your system administrator;14145 background jobs in queue"
issues
0
" channel is active but not fetched for about 6 hours"
1
2
3
4
“unprocessable mails: 1”
5
“scheduler may not run (last execution of Chat.cleanup 2 days over) - please contact your system administrator”
6
“14145 background jobs in queue”
Thank you very much for the help, I’m totally stuck I don’t now how to solve that.
I, [2019-03-02T20:54:28.847565 #17841-47114925338440] INFO -- : Setting.set('product_logo', "4f05f74a9601ef2bbbc6540483083f7d.png")
I, [2019-03-02T20:54:32.109158 #17841-47114925338440] INFO -- : Scheduler started.
I, [2019-03-02T20:54:32.115172 #17841-47114925338440] INFO -- : Cleanup of left over locked delayed jobs 2019-03-02 19:54:32 UTC started.
I, [2019-03-02T20:54:32.146690 #17841-47114925338440] INFO -- : Checking left over delayed job #<Delayed::Backend::ActiveRecord::Job id: 3092249, priority: 0, attempts: 0, handler: "--- !ruby/object:BackgroundJobSearchIndex\nobject: ...", last_error: nil, run_at: "2019-02-26 15:46:11", locked_at: "2019-02-26 15:46:12", failed_at: nil, locked_by: "host:helpdesk pid:21384", queue: nil, created_at: "2019-02-26 15:46:11", updated_at: "2019-02-26 15:46:11"> started.
I, [2019-03-02T20:54:32.282457 #17841-47114925338440] INFO -- : Scheduler stopped.
I, [2019-03-02T20:54:32.896597 #3706-47267957873360] INFO -- : Started GET "/api/v1/monitoring/health_check?_=1551529843206" for 179.26.8.63 at 2019-03-02 20:54:32 +0100
I, [2019-03-02T20:54:32.902985 #3706-47267957873360] INFO -- : Processing by MonitoringController#health_check as JSON
I, [2019-03-02T20:54:32.903042 #3706-47267957873360] INFO -- : Parameters: {"_"=>"1551529843206"}
I, [2019-03-02T20:54:32.929567 #3706-47267957873360] INFO -- : Completed 200 OK in 26ms (Views: 0.2ms | ActiveRecord: 14.7ms)
I, [2019-03-02T20:54:36.588875 #17872-47456895979360] INFO -- : Setting.set('product_logo', "4f05f74a9601ef2bbbc6540483083f7d.png")
Hi @lobiman - we fixed an issue just yesterday which caused high system load and an unstable overall system. Please update to the latest version of 2.9 and let us know how it went
The problem probably was an error while updating to 2.9. The reason why the scheduler was crashing on each startup was a older Job from an older Zammad Version, which was not completed.
Solution was:
Run the followed commands
Delayed::Job.where(“handler LIKE ‘%Observer::UserTicketCounter::BackgroundJob%’”).count
Delayed::Job.where(“handler LIKE ‘%Observer::UserTicketCounter::BackgroundJob%’”).delete_all
After we have restarted Zammad and monitor the Job count
Delayed::Job.count
Delayed::Job.first
@Benjamin maybe you have the same problem and this solution will help you.
