Hello. Tonight zammad got update, so my version is latest literally (but GUI still shows 3.1.x).
Telegram bot does not work. I did all movements from manual, connect my bot to zammad, got nice green indicator and that is all. When I typing in bot chat /start (enter) bla bla bla (enter), nothing received as ticket. in zammad production log i see only info messages.
My certificate bundle was updated today, https://api.telegram.org are fine.
I, [2019-10-09T00:07:10.027633 #796-47280003983240] INFO – : Started GET “/api/v1/channels_telegram?=1570568801793" for 10.10.3.10 at 2019-10-09 00:07:10 +0300
I, [2019-10-09T00:07:10.035439 #796-47280003983240] INFO – : Processing by ChannelsTelegramController#index as JSON
I, [2019-10-09T00:07:10.035545 #796-47280003983240] INFO – : Parameters: {"”=>“1570568801793”}
I, [2019-10-09T00:07:10.067842 #796-47280003983240] INFO – : Completed 200 OK in 32ms (Views: 2.7ms | ActiveRecord: 6.2ms)
I, [2019-10-09T00:07:15.774422 #866-70021288195740] INFO – : execute Channel.fetch (try_count 0)…
I, [2019-10-09T00:07:40.617310 #796-47280003981840] INFO – : Started PUT “/api/v1/channels_telegram/5” for 10.10.3.10 at 2019-10-09 00:07:40 +0300
I, [2019-10-09T00:07:40.626045 #796-47280003981840] INFO – : Processing by ChannelsTelegramController#update as JSON
I, [2019-10-09T00:07:40.626221 #796-47280003981840] INFO – : Parameters: {“api_token”=>“TOKEN_DELETED_BUT_IT_WAS_HERE”, “welcome”=>“Hello! Your Killerbo… Sorry, Supportbot online.”, “group_id”=>“1”, “id”=>“5”}
I, [2019-10-09T00:07:42.654289 #796-47280003981840] INFO – : Completed 200 OK in 2028ms (Views: 1.3ms | ActiveRecord: 10.7ms)
I, [2019-10-09T00:07:43.025854 #796-47280003982200] INFO – : Started GET “/api/v1/channels_telegram?=1570568801794" for 10.10.3.10 at 2019-10-09 00:07:43 +0300
I, [2019-10-09T00:07:43.033884 #796-47280003982200] INFO – : Processing by ChannelsTelegramController#index as JSON
I, [2019-10-09T00:07:43.033992 #796-47280003982200] INFO – : Parameters: {"”=>“1570568801794”}
I, [2019-10-09T00:07:43.072054 #796-47280003982200] INFO – : Completed 200 OK in 38ms (Views: 3.4ms | ActiveRecord: 5.9ms)
I, [2019-10-09T00:07:46.387402 #866-70021288195740] INFO – : execute Channel.fetch (try_count 0)…
2019-10-09T00:08:30.331541 #796-47280002903780] INFO – : Started PUT “/api/v1/channels_telegram/5” for 10.10.3.10 at 2019-10-09 00:08:30 +0300
I, [2019-10-09T00:08:30.339746 #796-47280002903780] INFO – : Processing by ChannelsTelegramController#update as JSON
I, [2019-10-09T00:08:30.339892 #796-47280002903780] INFO – : Parameters: {“api_token”=>“TOKEN_DELETED_BUT_IT_WAS_HERE”, “welcome”=>“Hello! Your Killerbo… Sorry, Supportbot online.”, “group_id”=>“1”, “id”=>“5”}
I, [2019-10-09T00:08:30.738129 #796-47280002903780] INFO – : Completed 200 OK in 398ms (Views: 1.3ms | ActiveRecord: 10.2ms)
I, [2019-10-09T00:08:31.097863 #796-47280003981460] INFO – : Started GET “/api/v1/channels_telegram?=1570568801795" for 10.10.3.10 at 2019-10-09 00:08:31 +0300
I, [2019-10-09T00:08:31.105990 #796-47280003981460] INFO – : Processing by ChannelsTelegramController#index as JSON
I, [2019-10-09T00:08:31.106131 #796-47280003981460] INFO – : Parameters: {"”=>“1570568801795”}
I, [2019-10-09T00:08:31.145765 #796-47280003981460] INFO – : Completed 200 OK in 39ms (Views: 13.0ms | ActiveRecord: 6.1ms)
I, [2019-10-09T00:08:47.640199 #866-70021288195740] INFO – : execute Channel.fetch (try_count 0)…
