Workflow with a custom object does not work properly
It is noticeable that in the core workflows, actions like “hide field” or “show field” are always successful when they are linked to ticket conditions such as “group” or “status” (marked with a star). However, if I add a custom object, such as the object “example” (regardless of whether it is a Boolean, single field, or similar) and specify a condition that should apply when the input is “yes,” linked with the action “add field ‘b’ if input=yes,” unfortunately, nothing happens, regardless of the workflow’s priority.
Is it generally not possible to apply conditions and actions to custom objects? Or is there some trick to it?
I found a solution and I am embarrassed: It is necessary to restart Zammad after creating objects.
