Used Zammad installation source: (source, package, …) deb
Operating system: Ubuntu 16.04
Browser + version: latest Chrome, latest Edge
Views should automaticly refresh.
I have a view (my tickets). If a ticket is assigned to me, I see in the view the badge with the amount of the tickets. For example it shows me 15. The view itselt shows only 7. After a refresh of the browser i see all the tickets (15). In version 2.4 I see always all tickets.
The strange thing is partially the views is working correct, but sometimes I have to refresh it manually.
Is there a way to debug this issue
I use my laptop and have a zammad tab open - I then put my laptop to sleep / standby, reactivate it 1-2 hours later and need to refresh the ticketsystem-page
I opened a second tab of zammad and it somehow does not refresh completely (proberbly because of websockets)
Other than that, up until now as long as my connection to the system stays active, I’ve not experienced such a problem yet.
Maybe your webserver service is restarting / reloading and causing this issue?
@thorsteneckel
I have count the jobs with Delayed::Job.count and the output is 44.
How can i check if the zammad processes (especially the Websocket and Scheduler) work properly?
If I run systemctl zammad status, it seems to work correctly. This is the output:
zammad.service
Loaded: loaded (/etc/systemd/system/zammad.service; enabled; vendor preset: enabled)
Active: active (running) since Mit 2018-07-04 16:34:46 CEST; 4min 11s ago
Main PID: 996 (sleep)
Tasks: 1
Memory: 116.0K
CPU: 945us
CGroup: /system.slice/zammad.service
└─996 /bin/sleep infinity
On this server runs only zammad with elastic search.
