I have changed the domain of the system and email addresses.
Now I have to actually relink the MS365 because I can’t send or receive mails anymore.
Leather I get the following error message after I authenticated with with MS365.
User Mismatch
The entered user for reauthentication differs from the user that was used for setting up your Microsoft365 channel initially.
To avoid fetching an incorrect Microsoft365 mailbox, the reauthentication process was aborted.
Please start the reauthentication again and enter the correct credentials.
Can’t use Channel::Driver::Imap: #<RuntimeError: Failed to refresh XOAUTH2 access_token of provider ‘microsoft365’: Request failed! ERROR: invalid_grant (AADSTS50173: The provided grant has expired due to it being revoked, a fresh auth token is needed. The user might have changed or reset their password. The grant was issued on ‘2023-05-03T16:10:30.6017261Z’ and the TokensValidFrom date (before which tokens are not valid) for this user is ‘2023-06-06T06:18:03.0000000Z’. Trace ID…
