Important:
- Used Zammad version: 2.8
- Used Zammad installation source: deb
- Browser + version: all
- By setting up the integrations method LDAP it should be possible to define the Port.
- I can set the Port by inserting the LDAP URL. For example (ldap://ldap.domain.com:3268
- It would be nice If its possible to insert a separate inpout field (number) to add the Port.
It’s not realy important (its works also) but it would be a nice UX Feature.
