Preparing to unpack .../zammad_5.0.0-1633402025.d288b48b.buster_amd64.deb ...
Unpacking zammad (5.0.0-1633402025.d288b48b.buster) over (4.1.0-1632293252.c9a3fc0d.buster) ...
dpkg: warning: unable to delete old directory '/opt/zammad/test/functional': Directory not empty
dpkg: warning: unable to delete old directory '/opt/zammad/test': Directory not empty
dpkg: warning: unable to delete old directory '/opt/zammad/lib/assets': Directory not empty
dpkg: warning: unable to delete old directory '/opt/zammad/spec/fixtures/smime': Directory not empty
dpkg: warning: unable to delete old directory '/opt/zammad/spec/fixtures': Directory not empty
dpkg: warning: unable to delete old directory '/opt/zammad/spec': Directory not empty
== 20210729183242 SetUserSourceLdapFromExternalSync: migrating ================
rake aborted!
StandardError: An error has occurred, all later migrations canceled:
Mysql2::Error: Field 'activity_stream_object_id' doesn't have a default value
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:131:in `_query'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:131:in `block in query'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:130:in `handle_interrupt'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/mysql2-0.5.3/lib/mysql2/client.rb:130:in `query'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:201:in `block (2 levels) in execute'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:200:in `block in execute'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:728:in `block (2 levels) in log'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:727:in `block in log'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_adapter.rb:718:in `log'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:199:in `execute'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/mysql/database_statements.rb:41:in `execute'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract_mysql_adapter.rb:210:in `execute_and_free'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/mysql/database_statements.rb:46:in `exec_query'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:135:in `exec_insert'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/composite_primary_keys-12.0.10/lib/composite_primary_keys/connection_adapters/abstract/database_statements.rb:6:in `insert'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `insert'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:375:in `_insert_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/composite_primary_keys-12.0.10/lib/composite_primary_keys/persistence.rb:64:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/counter_cache.rb:166:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/locking/optimistic.rb:79:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/attribute_methods/dirty.rb:211:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/callbacks.rb:331:in `block in _create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:135:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:825:in `_run_create_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/callbacks.rb:331:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/timestamp.rb:110:in `_create_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:905:in `create_or_update'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/callbacks.rb:327:in `block in create_or_update'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:825:in `_run_save_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/callbacks.rb:327:in `create_or_update'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/timestamp.rb:128:in `create_or_update'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:470:in `save'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/validations.rb:47:in `save'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:314:in `block in save'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:375:in `block in with_transaction_returning_status'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:278:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:212:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:366:in `with_transaction_returning_status'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:314:in `save'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/suppressor.rb:44:in `save'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:38:in `create'
/opt/zammad/app/models/activity_stream.rb:82:in `add'
/opt/zammad/app/models/application_model/can_activity_stream_log.rb:46:in `activity_stream_log'
/opt/zammad/app/models/concerns/has_activity_stream_log.rb:49:in `activity_stream_update'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:428:in `block in make_lambda'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:238:in `block in halting_and_conditional'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:517:in `block in invoke_after'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:517:in `each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:517:in `invoke_after'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:136:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:825:in `_run_update_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/callbacks.rb:335:in `_update_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/timestamp.rb:123:in `_update_record'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/autosave_association.rb:366:in `around_save_collection_association'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.1/lib/active_support/callbacks.rb:139:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:503:in `save!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/validations.rb:53:in `save!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:318:in `block in save!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/transactions.rb:318:in `save!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/suppressor.rb:48:in `save!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:635:in `block in update!'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/persistence.rb:633:in `update!'
/opt/zammad/db/migrate/20210729183242_set_user_source_ldap_from_external_sync.rb:13:in `block in change'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:70:in `block (2 levels) in find_each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:70:in `each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:70:in `block in find_each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:136:in `block in find_in_batches'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:238:in `block in in_batches'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:222:in `loop'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:222:in `in_batches'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:135:in `find_in_batches'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/relation/batches.rb:69:in `find_each'
/opt/zammad/db/migrate/20210729183242_set_user_source_ldap_from_external_sync.rb:12:in `change'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:828:in `exec_migration'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:812:in `block (2 levels) in migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:811:in `block in migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:471:in `with_connection'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:810:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1002:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1310:in `block in execute_migration_in_transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1363:in `ddl_transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1309:in `execute_migration_in_transaction'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1281:in `block in migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1280:in `each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1280:in `migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1229:in `block in migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1382:in `with_advisory_lock'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1229:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1061:in `up'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/migration.rb:1036:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/tasks/database_tasks.rb:238:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/railties/databases.rake:86:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/railties/databases.rake:84:in `each'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.1/lib/active_record/railties/databases.rake:84:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:63:in `load'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:63:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:494:in `exec'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:30:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/cli.rb:24:in `start'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/exe/bundle:49:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/lib/bundler/friendly_errors.rb:130:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/bundler-2.2.16/exe/bundle:37:in `<top (required)>'
/opt/zammad/bin/bundle:5:in `load'
/opt/zammad/bin/bundle:5:in `<main>'
Caused by:
ActiveRecord::NotNullViolation: Mysql2::Error: Field 'activity_stream_object_id' doesn't have a default value
###### Same as above, but 32k char limit.
Caused by:
Tasks: TOP => db:migrate
