Hello zammad team!
About my environment:
- zammad version: 3.3.0
- installation method: build from source code
- OS: CentOS Linux release 7.8.2003
- database: postgresql-11
- elk: 7.6.2
Number of posgresql DB - 1
Number of ELK clusters - 1
Number of zammad application nodes - 2
Problem description:
after we added second zammad node, sometimes errors began to appear in the logs:
[root@node02:~]# cat /opt/zammad/log/scheduler_out.log-20200518
"ERROR: Can't process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/4d9e4a93b68b4438322bab982c69919f.eml, please create an issue at https://github.com/zammad/zammad/issues"
"ERROR: #<ActiveRecord::RecordNotUnique: PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "index_users_on_login"\nDETAIL: Key (lower(login::text))=([ajbastos23@gmail.com](mailto:ajbastos23@gmail.com)) already exists.\n: INSERT INTO "users" ("login", "firstname", "lastname", "email", "updated_by_id", "created_by_id", "created_at", "updated_at") VALUES ($1, $2, $3, $4, $5, $6, $7, $8) RETURNING "id">"
"ERROR: Can't process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/62f6155ec112f6ca8dd277fa67861ebf.eml, please create an issue at https://github.com/zammad/zammad/issues"
"ERROR: #<ActiveRecord::RecordNotUnique: PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "index_users_on_login"\nDETAIL: Key (lower(login::text))=([generosoq@yahoo.com](mailto:generosoq@yahoo.com)) already exists.\n: INSERT INTO "users" ("login", "firstname", "lastname", "email", "updated_by_id", "created_by_id", "created_at", "updated_at") VALUES ($1, $2, $3, $4, $5, $6, $7, $8) RETURNING "id">"
"ERROR: Can't process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/b9c7487984b039faae9e12be32a70a06.eml, please create an issue at https://github.com/zammad/zammad/issues"
"ERROR: #<ActiveRecord::RecordNotUnique: PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "index_users_on_login"\nDETAIL: Key (lower(login::text))=([dgb.dejuan@gmail.com](mailto:dgb.dejuan@gmail.com)) already exists.\n: INSERT INTO "users" ("login", "firstname", "lastname", "email", "updated_by_id", "created_by_id", "created_at", "updated_at") VALUES ($1, $2, $3, $4, $5, $6, $7, $8) RETURNING "id">"
"ERROR: Can't process email, you will find it for bug reporting under /opt/zammad/tmp/unprocessable_mail/a12fd678f9d913ec127eb0725a594e26.eml, please create an issue at https://github.com/zammad/zammad/issues"
Most emails are processed without such errors
On both zammad nodes errors accumulate about unprocessable mails.
On both nodes zammad health check monitoring indicates a problem with unprocessable mails
how we can solve this problem?
