Dear Community,
I try to implement a second instance of zammad via zammad-docker-univention. Sadly nobody did respond there.
So I’ve some questions:
- is it possible to run the container without elastic search
- how to check the elastic search configuration within the container
- Any problems using one elastic search instance for different zammad indices?
Thanks a lot,
Best,
Meg
