Unable to create and use ticket templates
  • Used Zammad version: 6.1
  • Used Zammad installation type: (source, package, docker-compose, …) Docker
  • Operating system: Linux
  • Browser + version:
    Edge
  • Want to create ticket templates so that the ticket creation would be easy for the customers
  • the templates are not applying and the default template is only at the ticket creation page
not able to find the delete and save as options and the template is not applying
(upload://6aZfZfHhVTYyaIIt75jhtNKh9rp.png)
Hi @KannanK. Not sure if I understood your correctly, but ticket templates are only available for agents, not for customers.
okay, can we remove the status option to the customer in their ticket form
You can check CoreWorkflow for this: Core Workflows — Zammad Admin Documentation documentation
