59: from /opt/zammad/bin/rails:9:in `<main>'
58: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.11.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
57: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.11.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
56: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands.rb:18:in `<main>'
55: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/command.rb:46:in `invoke'
54: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/command/base.rb:69:in `perform'
53: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
52: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
51: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
50: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `perform'
49: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `eval'
48: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `<main>'
47: from /opt/zammad/app/models/translation/synchronizes_from_po.rb:11:in `sync'
46: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:in `each'
45: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/relation/delegation.rb:88:in `each'
44: from /opt/zammad/app/models/translation/synchronizes_from_po.rb:12:in `block in sync'
43: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/transactions.rb:212:in `transaction'
42: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
41: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
40: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
39: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
38: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
37: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
36: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
35: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
34: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
33: from /opt/zammad/app/models/translation/synchronizes_from_po.rb:13:in `block (2 levels) in sync'
32: from /opt/zammad/app/models/translation/synchronizes_from_po.rb:62:in `sync_locale_from_po'
31: from /opt/zammad/app/models/translation.rb:223:in `import'
30: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:530:in `bulk_import'
29: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:696:in `import_helper'
28: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:761:in `import_with_validations'
27: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:820:in `import_without_validations_or_callbacks'
26: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:820:in `each_slice'
25: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:820:in `each'
24: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/import.rb:824:in `block in import_without_validations_or_callbacks'
23: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-import-1.3.0/lib/activerecord-import/adapters/postgresql_adapter.rb:29:in `insert_many'
22: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:88:in `select_values'
21: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:94:in `select_rows'
20: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/query_cache.rb:107:in `select_all'
19: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:70:in `select_all'
18: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract/database_statements.rb:489:in `select'
17: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql/database_statements.rb:98:in `exec_query'
16: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:654:in `execute_and_clear'
15: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:673:in `exec_no_cache'
14: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract_adapter.rb:718:in `log'
13: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
12: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract_adapter.rb:727:in `block in log'
11: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
10: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
9: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
8: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
7: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
6: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/abstract_adapter.rb:728:in `block (2 levels) in log'
5: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:674:in `block in exec_no_cache'
4: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
3: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
2: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.4.8/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
1: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `block (2 levels) in exec_no_cache'
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `async_exec': ERROR: insert or update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" (PG::ForeignKeyViolation)
DETAIL: Key (created_by_id)=(1) is not present in table "users".
/opt/zammad/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.4.8/lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `async_exec': PG::ForeignKeyViolation: ERROR: insert or update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" (ActiveRecord::InvalidForeignKey)
-- Nevermind, no es_url is set, leaving Elasticsearch untouched ...!
-- The above is all right if you don't want to use Elasticsearch (locally) - if this is not intended, consult https://docs.zammad.org !
12: from /opt/zammad/bin/rails:9:in `<main>'
11: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.11.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
10: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.11.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
9: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands.rb:18:in `<main>'
8: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/command.rb:46:in `invoke'
7: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/command/base.rb:69:in `perform'
6: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
5: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
4: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
3: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `perform'
2: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `eval'
1: from /opt/zammad/vendor/bundle/ruby/2.7.0/gems/railties-6.0.4.8/lib/rails/commands/runner/runner_command.rb:45:in `<main>'
/opt/zammad/app/models/setting.rb:37:in `set': Can't find config setting 'es_url' (RuntimeError)
# Enforcing 0600 on database.yml ...
Fresh install Ubuntu 18.04 LTS
Create a postgres database cluster with locale en_US.utf8
Thanks for your answer. You are totally right, with the correct environment it works as a non brainer.
In the meantime I found the problem. I previously installed Ubuntu 18.04 with a german charset. Therefore postgresql was also installed with a german charset. I removed the default instance and installed a new database instance with utf8 charset but still the db scripts didn’t work and were not able to create user and database.
Therefore I completely removed the virtual linux box and recreated it by then using Ubuntu 20.04 LTS. In this case I chose directly us english as installation locale and then zammad installed like a charm.
I think it is necessary that the linux box itself is an english one to have utf8 as a default for everything.
