New contact to appear in exchange synchronised folder
Add customer in zammad while creating ticket,
New contact does not appear in exchange synchronised folder
Setup exchange sync to sync to a contacts folder
Create customer in zammad
Manually sync (or wait for automatic sync)
Check exchange for newly created user.
It would be lovely if we could have two-way sync (unless I’m missing something) with exchange. The synchronisation interval is too long for agents to create new customer in exchange, and to wait for it to populate in zammad, and the other way around means that any customer created in zammad never leaves zammad, and syncing with exchange becomes only an “import”
I personally do not like the idea (that’s no official Zammad statement), as I think that Exchange and LDAP as source shall always be current.
Also, if you happen to edit both parts (Exchange and Zammad) inbetween two syncs, you’ll end up in conflicts that need to be solved. This requires quite some logic and will -in my opinion- add quite some complexity into the UI.
