Is it possible to install the zammad in two tire architecture where we can install the DB Server in behand firewall and the app/web in front of firewall.
Please share the document,
sure you can, just change the host value in the config/database.yml to point to your database host.
see: Install from source — Zammad documentation
Also make sure your firewall allows the DB connection from zammad.
