I wanted a field that should be filled when the closing the ticket.
So I made a field called “summary” and tried to make a trigger which gives a notification when the ticket gets closed and the field is still empty.
But I can not check if the field is empty in the trigger.
Is there a workaround for that?
I tried setting a default value like ° and check on that but this gets not set when the ticket is created by mail.
