- Used Zammad version: 4.1.x
- Used Zammad installation type: Package
- When a new ticket is created, trigger should send a Mail to Reply-To Adress. Trigger is in fact a modified main setup comes with Zammad installed. (auto reply (on new tickets),
Settings of trigger: action is created, state is new, type is email, sender is customer
- Trigger only works, when Channels > email > settings > “Sender based on Reply-To header” is set to none (-). In this case, trigger works but send mail back to mail address where it came from. When settings are set to “Take reply-to header as sender/from of email” or “Take reply-to header as sender/from of email and use realname of origin from.”, trigger is not working.
- I’ve send three tickets with each setting under “Sender based on Reply-To header”, trigger only worked when settings were on “-”, but send the content to from address not to reply-to address.
