Inline
1
i have a siple question.
Is it possible to write more than one word per line in a Trigger?
For example (can be seen in the screenshot)
Thank you in advance
You could try regular expressions.
Possibly regex:(A|B)
could work for you.
Are regex supported in triggers now? my understanding is that they only work in email filters???
Awww geez sorry.
I must have puzzled that with something because I thought someone said it’s implemented.
My bad - the fitting issue would life here (if you want to subscribe to it)
That also means that your desired functionality is not possible as of now.
Zammad triggers do not support AND/OR situations on exact same attributes.
Zammads triggers are AND conditions of attributes which may not be used twice.
system
Closed
5
