- Used Zammad version: 6.0.0
- Operating system: ubuntu 22.04
HI,
I’ve encountered an issue with Zammad where the command Ticket::StateType.pluck(:id, :name)
returns an empty array []
in the Rails console,
even though the GUI displays the expected values for ticket states.
Additionally, when attempting to add a new ticket status, I receive the following error message:
/usr/local/bundle/gems/railties-6.1.7.4/lib/rails/railtie/configuration.rb:97:in
`method_missing': undefined method `db_case_sensitive'
for #<Rails::Application::Configuration:0x00007f79b4cd02c8
@root=#<Pathname:/opt/zammad>, @generators=#<Rails::Configuration::Generators:0x00007f79b670aa80 @aliases={}, @options={:rails=>{:orm=>:active_record, :test_framework=>:rspec, :integration_tool=>:test_unit, :system_tests=>:test_unit}, :active_record=>{:migration=>true, :timestamps=>true}
I would appreciate any assistance in understanding and resolving this issue.
Thank you!
