I like to edit the template for our Slack / Mattermost Notification. I could not find it in the settings. Is it possible to adjust the template and where can I find it?
Kind Regards,
Stephan
Kind Regards,
Stephan
Thanks! I’ll have a look.
@thorsteneckel One more question: If I change that template - an update of zammad will overwrite it, right? If so, is there a way to adjust the templates without being overwritten by an update?
This topic was automatically closed 30 days after the last reply. New replies are no longer allowed.
