I’m stucked in this logs loop when i startup the containers, what’s causing this?
zammad_init exited with code 0
zammad_db | LOG: incomplete startup packet
zammad_init | initialising / updating database...
zammad_sc | I, [2021-04-22T10:52:12.210651 #1-69914820069420] INFO -- : execute Channel.fetch (try_count 0)...
zammad_sc | I, [2021-04-22T10:52:12.212451 #1-69914820069420] INFO -- : ended Channel.fetch took: 0.007893989 seconds.
zammad_init | I, [2021-04-22T10:52:14.585683 #21-46936230467940] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
", "Ticket", "User"])
zammad_init | changing settings...
zammad_init | I, [2021-04-22T10:52:18.686651 #22-47270969047420] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:52:19.493812 #22-47270969047420] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_init | I, [2021-04-22T10:52:23.206578 #23-47155127122260] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:52:24.015913 #23-47155127122260] INFO -- : Setting.set('es_index', "zammad")
zammad_init | I, [2021-04-22T10:52:35.532550 #21-47171110549860] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:52:39.649536 #22-47195416451420] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:52:40.496797 #22-47195416451420] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_sc | I, [2021-04-22T10:52:42.221328 #1-69914820069420] INFO -- : execute Channel.fetch (try_count 0)...
zammad_sc | I, [2021-04-22T10:52:42.223058 #1-69914820069420] INFO -- : ended Channel.fetch took: 0.008184323 seconds.
zammad_sc | I, [2021-04-22T10:52:42.451076 #1-47060877392220] INFO -- : Scheduler running...
zammad_sc | I, [2021-04-22T10:52:42.460952 #1-47060877392220] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
zammad_sc | I, [2021-04-22T10:52:42.461476 #1-47060877392220] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
zammad_sc | I, [2021-04-22T10:52:42.461617 #1-47060877392220] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
zammad_sc | I, [2021-04-22T10:52:42.461742 #1-47060877392220] INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
zammad_sc | I, [2021-04-22T10:52:42.462062 #1-47060877392220] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
zammad_sc | I, [2021-04-22T10:52:42.462565 #1-47060877392220] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
zammad_init | I, [2021-04-22T10:52:44.169888 #23-47349645982060] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:52:44.864620 #23-47349645982060] INFO -- : Setting.set('es_index', "zammad")
zammad_init | I, [2021-04-22T10:52:56.737243 #21-47322910759280] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:00.654709 #22-46992952293720] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:01.509420 #22-46992952293720] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_sc | I, [2021-04-22T10:53:01.995382 #1-69914819887440] INFO -- : execute Import::OTRS.diff_worker (try_count 0)...
zammad_sc | I, [2021-04-22T10:53:01.999235 #1-69914819887440] INFO -- : ended Import::OTRS.diff_worker took: 0.009187948 seconds.
zammad_init | I, [2021-04-22T10:53:05.189018 #23-47294210414940] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:06.015188 #23-47294210414940] INFO -- : Setting.set('es_index', "zammad")
zammad_sc | I, [2021-04-22T10:53:12.231301 #1-69914820069420] INFO -- : execute Channel.fetch (try_count 0)...
zammad_sc | I, [2021-04-22T10:53:12.232886 #1-69914820069420] INFO -- : ended Channel.fetch took: 0.007439554 seconds.
zammad_init | I, [2021-04-22T10:53:17.991668 #21-47051897248100] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:21.954636 #22-47374690908540] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:22.717023 #22-47374690908540] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_init | I, [2021-04-22T10:53:26.135500 #23-47155632011620] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:26.924651 #23-47155632011620] INFO -- : Setting.set('es_index', "zammad")
zammad_init | I, [2021-04-22T10:53:39.166306 #21-47393232828780] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_sc | I, [2021-04-22T10:53:42.239169 #1-69914820069420] INFO -- : execute Channel.fetch (try_count 0)...
zammad_sc | I, [2021-04-22T10:53:42.240465 #1-69914820069420] INFO -- : ended Channel.fetch took: 0.005630415 seconds.
zammad_sc | I, [2021-04-22T10:53:42.523941 #1-47060877392220] INFO -- : Scheduler running...
zammad_sc | I, [2021-04-22T10:53:42.532457 #1-47060877392220] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
zammad_sc | I, [2021-04-22T10:53:42.532741 #1-47060877392220] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
zammad_sc | I, [2021-04-22T10:53:42.532861 #1-47060877392220] INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
zammad_sc | I, [2021-04-22T10:53:42.532943 #1-47060877392220] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
zammad_sc | I, [2021-04-22T10:53:42.533151 #1-47060877392220] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
zammad_sc | I, [2021-04-22T10:53:42.533659 #1-47060877392220] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
zammad_init | I, [2021-04-22T10:53:43.233456 #22-47048910207340] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:44.056114 #22-47048910207340] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_init | I, [2021-04-22T10:53:47.789028 #23-47059431651700] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:53:48.533819 #23-47059431651700] INFO -- : Setting.set('es_index', "zammad")
zammad_init | I, [2021-04-22T10:54:00.476118 #21-47370809743720] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:04.522782 #22-47232426539360] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:05.478844 #22-47232426539360] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_init | I, [2021-04-22T10:54:09.153993 #23-47419787245900] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:09.890372 #23-47419787245900] INFO -- : Setting.set('es_index', "zammad")
zammad_sc | I, [2021-04-22T10:54:12.248744 #1-69914820069420] INFO -- : execute Channel.fetch (try_count 0)...
zammad_sc | I, [2021-04-22T10:54:12.250672 #1-69914820069420] INFO -- : ended Channel.fetch took: 0.008418672 seconds.
zammad_init | I, [2021-04-22T10:54:21.766155 #21-47281154447720] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:25.694023 #22-47018768726360] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:26.522030 #22-47018768726360] INFO -- : Setting.set('es_url', "http://zammad_es:9200")
zammad_init | I, [2021-04-22T10:54:29.766585 #23-47042727696740] INFO -- : Setting.set('models_searchable', ["Chat::Session", "KnowledgeBase::Answer::Translation", "Organization
zammad_init | I, [2021-04-22T10:54:30.486022 #23-47042727696740] INFO -- : Setting.set('es_index', "zammad")
