- Used Zammad version: 6.4.1
- Operating system: Ubuntu 24.04
- Browser + version: Chrome, Firefox, Edge
- Users should be able to access Zammad via SSO authentication (Active Directory), using the same user logged into the operating system.
- The user is unable to access it, receiving a message stating that the user was not found.
- I successfully configured the LDAP integration. I can log into the system with an Active Directory user through Zammad’s login form. I enabled SSO in the administration panel and configured Kerberos and Apache.
Apparently, Zammad detects the kerberos user, but the Zammad log says the user was not found.
I, [2025-02-20T15:56:39.274161#786-184360] INFO -- : Started POST "/auth/sso" for 172.16.38.11 at 2025-02-20 15:56:39 -0400
I, [2025-02-20T15:56:39.278032#786-184360] INFO -- : Processing by SessionsController#create_sso as HTML
I, [2025-02-20T15:56:39.278088#786-184360] INFO -- : Parameters: {"authenticity_token"=>"[FILTERED]"}
I, [2025-02-20T15:56:39.281554#786-184360] INFO -- : User '“ldap-username”' could not be found. (Exceptions::NotAuthorized)
app/controllers/sessions_controller.rb:50:in `create_sso'
I, [2025-02-20T15:56:39.283109#786-184360] INFO -- : Completed 401 Unauthorized in 5ms (Views: 0.8ms | ActiveRecord: 0.7ms | Allocations: 2477)
May you helpe me?
