Sort Order of Tags
I’m adding more tags in my zammad on-premise installation because I like the possibility to filter into categories.
It seems that the tags are sorted alphabetically in the admin panel. However if I like to add a tag to a ticket, the sort order is by date of creation and also limited to 10 tags
Is there any way to change the sort order and to show all tags?
There’s no option to adjust the tag behavior.
The issue can be workarrounded by typing the beginning of the tag to filter the list.
Objects like select fields may be a better approach in your scenario.
