[SOLVED] Zammad error in login
Hi, i have a big trouble when try access to zammad before that i update and upgrade the system operative linux ubuntu and appearme this message and also i see others services
Also i see in the log of Posgressql and Zammad
postgresql-12-main.log
production.log
I try use recovery password but the webpage not load. Somebody can help me please.
Hey buddy,
you are flooding…
This is a duplicate of your previous post Zammad trouble connection from 7 hours ago…
Please don’t do that. It is not polite… and most likely people will hate you for this :slight_smile:
Be patient. Most of us do not work for Zammad and help here in our spare time (when we have some, that is…)
Someone will eventually reply to you…
Regards
Martin
Hi, @rsysadmin i can’t find my case and I looked for it everywhere so I thought it had not been saved, I proceed to delete or close the other case. Thanks for letting me know where it was.
@klausneil did you find a solution? I got the same error when doint the upgrade …
Sorry…
forget what i wrote. I just saw that you use a postgres DB.
Hi @newmy , i force a reinstallation with uninstall mysql-common with apt remove mysql-common -y (is the unique module) and reboot my server, late i put apt install zammad -y and all work, in all this process appearme postgresql installation and finally all fine.
@oschmidt anyway thanks for your answer.
