I would like to bring this up again, because the need still exists for us.
After looking at the current code, the central path for built-in system notification emails seems to be:
lib/notification_factory/mailer.rb
especially NotificationFactory::Mailer.deliver
Ticket communication already uses the existing secure mailing infrastructure by passing security into channel.deliver. A possible implementation approach for system notifications could be to reuse the existing S/MIME notification option handling, for example via:
SecureMailing::SMIME::NotificationOptions
The requested scope would be signing only, not encryption:
If S/MIME integration is enabled,
and the configured notification_sender has a valid private S/MIME certificate,
system notification emails should be S/MIME-signed.
Open design question:
Should this happen automatically when S/MIME is enabled and a matching certificate exists, or should there be a separate admin setting, e.g. smime_sign_system_notifications?
I would be happy with either approach. The important part for us is that built-in system emails such as password reset messages, signup/account emails, admin/security tokens and similar notifications can be signed without relying on an external mail gateway workaround.
I think admins have to decide, similar to the trigger approach. However, itβs sonewhat more complicated, because triggers can run in a much narrower scope than a notification does.
I agree that admins should decide this explicitly. I also see the difference to triggers: trigger-based email notifications can be scoped quite narrowly, while built-in system notifications are broader and cover different use cases.
I prepared a small draft implementation as a starting point for discussion:
The draft currently uses a global opt-in setting:
default: disabled
signing only, no encryption
applies to built-in system notifications sent through NotificationFactory::Mailer
if no matching private S/MIME certificate exists for notification_sender, delivery continues unsigned
This is intentionally conservative and does not change existing behavior by default.
If a more granular approach fits Zammad better, one could adjust the design in that direction. Possible options might be:
separate signing policies per notification type/template,
signing only selected security-sensitive templates such as password reset, signup/account confirmation, admin/security tokens,
or keeping a single global opt-in switch as a first iteration.
