Is there a way to pipe the raw content of an email to rspamd’s bayes training process ?
I’ve found https://git.shackspace.de/server/zammad2rspamd but I have no idea how to get this into zammad. I’ve tried loading both .json files using the ‘packages’ admin menu, but they are not recognised as being valid
I probably won’t be able to help you much, but I can at least tell you that it’s definitely not a Zammad plugin. From looking at the code it looks like a Node.js application that runs on its own and uses Zammad’s REST api to find spam tickets, and then pipe them to rspamc. You need to make a copy of config.js.dist -> config.js and then configure it how to access your Zammad/rspamd instances and the queries how to find spam/ham tickets, and then run it with Node.js.
OK, then it confirms my understanding that this is some standlone stuff. Is there some zammad plugin that pipes the content of a ticket to something external ? Maybe I could adapt the code to pipe it to rspamd’s API
