Browser + version: Safari & Chrome, both current versions
when I enter something in the search field and press Enter, some kind of search should start
nothing happens by pressing Enter and I don’t get any search-recommendations while typing (I’m unfamiliar with zammad so I don’t no if this should be there)
root@rsfs3:~# systemctl status elasticsearch
● elasticsearch.service - LSB: Starts elasticsearch
Loaded: loaded (/etc/init.d/elasticsearch; bad; vendor preset: enabled)
Active: active (running) since Fr 2018-02-02 15:07:11 CET; 2min 49s ago
Docs: man:systemd-sysv-generator(8)
Process: 1164 ExecStart=/etc/init.d/elasticsearch start (code=exited, status=0/SUCCESS)
Tasks: 34
Memory: 237.2M
CPU: 5.251s
CGroup: /system.slice/elasticsearch.service
└─1283 /usr/lib/jvm/java-8-openjdk-amd64/bin/java -Xms256m -Xmx1g -Djava.awt.headless=true -XX:+UseParNewGC -XX:+UseConcMarkSweepGC -XX:CMSInitiat
Feb 02 15:07:11 rsfs3 systemd[1]: Starting LSB: Starts elasticsearch...
Feb 02 15:07:11 rsfs3 elasticsearch[1164]: * Starting Elasticsearch Server
Feb 02 15:07:11 rsfs3 elasticsearch[1164]: ...done.
Feb 02 15:07:11 rsfs3 systemd[1]: Started LSB: Starts elasticsearch.
hm I ried to set START_DAEMON to true and restarted first elasticsearch, then the whole machine, but still no search. It seems to be the culprit because in all other fields where a search should be performed (username in tickets…) it does not search too
