Since a few day the scheduler is not working properly. First i thought it was just because of some unprocessable mails so i fired up
zammad run rails r 'Channel::EmailParser.process_unprocessable_mails'
and thought everything was fine.
But apparently something else is blocking Zammad to work properly.
- Used Zammad version: [zammad 4.0.0]
- Used Zammad installation type:package
- Operating system: Ubuntu 18.04.
Scheduler not running under monitoring
Emails doesn’t get processed
I, [2021-04-29T06:05:36.869292 #16576-46973096098160] INFO -- : execute Channel.fetch (try_count 0)...
I, [2021-04-29T06:05:36.882490 #16576-46973096098160] INFO -- : fetching imap (outlook.office365.com/zammad@hit-suetterlin.de port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=true,auth_type=XOAUTH2)
I, [2021-04-29T06:05:37.715871 #16576-46973096098160] INFO -- : - no message
I, [2021-04-29T06:05:37.715948 #16576-46973096098160] INFO -- : done
I, [2021-04-29T06:05:37.730165 #16576-46973096098160] INFO -- : ended Channel.fetch took: 0.865971363 seconds.
I, [2021-04-29T06:05:38.153279 #16576-46973024647600] INFO -- : Scheduler running...
I, [2021-04-29T06:05:38.156385 #16576-46973024647600] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2021-04-29T06:05:38.160745 #16576-46973095459480] INFO -- : execute Ticket.process_auto_unassign (try_count 0)...
I, [2021-04-29T06:05:38.162406 #16576-46973095459480] INFO -- : ended Ticket.process_auto_unassign took: 0.005677045 seconds.
I, [2021-04-29T06:05:47.832093 #621-69840644155540] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:47 +0200
I, [2021-04-29T06:05:47.838194 #621-69840644155540] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:47.838284 #621-69840644155540] INFO -- : Parameters: {"data"=>{"event"=>"login"}}
I, [2021-04-29T06:05:47.843151 #621-69840644155540] INFO -- : client(2685562622) new client connection
I, [2021-04-29T06:05:47.845466 #621-69840644155540] INFO -- : Completed 200 OK in 7ms (Views: 0.2ms | ActiveRecord: 0.3ms)
I, [2021-04-29T06:05:47.876290 #621-69840644155540] INFO -- : Started POST "/api/v1/message_receive" for 37.201.138.73 at 2021-04-29 06:05:47 +0200
I, [2021-04-29T06:05:47.880606 #621-69840644155540] INFO -- : Processing by LongPollingController#message_receive as JSON
I, [2021-04-29T06:05:47.880687 #621-69840644155540] INFO -- : Parameters: {"client_id"=>"2685562622"}
I, [2021-04-29T06:05:47.909333 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:47 +0200
I, [2021-04-29T06:05:47.915943 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:47.916027 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"login", "fingerprint"=>"-1489638817"}}
I, [2021-04-29T06:05:47.921956 #621-69840638571120] INFO -- : Completed 200 OK in 6ms (Views: 0.1ms | ActiveRecord: 0.2ms)
I, [2021-04-29T06:05:47.954110 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:47 +0200
I, [2021-04-29T06:05:47.958457 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:47.958529 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"login", "session_id"=>"ca2aa7d05e4ac804f6401a3ac349fa54", "fingerprint"=>"-1489638817"}}
I, [2021-04-29T06:05:47.964642 #621-69840638571120] INFO -- : Completed 200 OK in 6ms (Views: 0.2ms | ActiveRecord: 0.3ms)
I, [2021-04-29T06:05:47.997397 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:47 +0200
I, [2021-04-29T06:05:48.001733 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:48.001796 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"chat_status_agent"}}
I, [2021-04-29T06:05:48.007098 #621-69840638571120] INFO -- : Completed 200 OK in 5ms (Views: 0.1ms | ActiveRecord: 0.2ms)
I, [2021-04-29T06:05:48.040849 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:48 +0200
I, [2021-04-29T06:05:48.045156 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:48.045240 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"ticket_overview_select", "data"=>{"view"=>"all_open"}}}
I, [2021-04-29T06:05:48.052311 #621-69840638571120] INFO -- : Completed 200 OK in 7ms (Views: 0.2ms | ActiveRecord: 0.3ms)
I, [2021-04-29T06:05:48.084983 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:48 +0200
I, [2021-04-29T06:05:48.089263 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:48.089335 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"ticket_overview_select", "data"=>{"view"=>"all_open"}}}
I, [2021-04-29T06:05:48.095086 #621-69840638571120] INFO -- : Completed 200 OK in 6ms (Views: 0.2ms | ActiveRecord: 0.2ms)
I, [2021-04-29T06:05:48.122368 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:48 +0200
I, [2021-04-29T06:05:48.126681 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:48.126752 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"2685562622", "data"=>{"event"=>"ticket_overview_select", "data"=>{"view"=>"all_open"}}}
I, [2021-04-29T06:05:48.132497 #621-69840638571120] INFO -- : Completed 200 OK in 6ms (Views: 0.2ms | ActiveRecord: 0.3ms)
I, [2021-04-29T06:05:48.166390 #16576-46973024647600] INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
I, [2021-04-29T06:05:48.166505 #16576-46973024647600] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2021-04-29T06:05:48.166538 #16576-46973024647600] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2021-04-29T06:05:48.166569 #16576-46973024647600] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2021-04-29T06:05:48.166754 #16576-46973024647600] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
E, [2021-04-29T06:05:48.885339 #615-47079581710740] ERROR -- : #<JSON::ParserError: 783: unexpected token at ''>
E, [2021-04-29T06:05:48.885825 #615-47079581710740] ERROR -- : error in reading/parsing session file '/opt/zammad/tmp/websocket_production/2685562622/session', remove session.
E, [2021-04-29T06:05:48.885805 #621-69840644155540] ERROR -- : Invalid client_id in receive loop! (Exceptions::UnprocessableEntity)
/opt/zammad/app/controllers/long_polling_controller.rb:93:in `rescue in message_receive'
/opt/zammad/app/controllers/long_polling_controller.rb:62:in `message_receive'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/abstract_controller/base.rb:194:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/callbacks.rb:109:in `block in run_callbacks'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:18:in `block (4 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/notifications.rb:180:in `subscribed'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:17:in `block (3 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb:16:in `block (2 levels) in <module:HasSecureContentSecurityPolicyForDownloads>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/callbacks.rb:118:in `instance_exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/opt/zammad/app/controllers/application_controller/handles_transitions.rb:14:in `handle_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/callbacks.rb:136:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/notifications.rb:168:in `block in instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/notifications.rb:168:in `instrument'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/abstract_controller/base.rb:134:in `process'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.4.5/lib/action_view/rendering.rb:32:in `process'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal.rb:191:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_controller/metal.rb:252:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:420:in `call_app!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-saml-1.10.1/lib/omniauth/strategies/saml.rb:89:in `other_phase'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:190:in `call!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:169:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/strategy.rb:192:in `call!'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/omniauth-1.9.1/lib/omniauth/builder.rb:45:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/rack/logger.rb:38:in `call_app'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/rack/logger.rb:26:in `block in call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/tagged_logging.rb:71:in `block in tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/tagged_logging.rb:28:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/tagged_logging.rb:71:in `tagged'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/rack/logger.rb:26:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.4.5/lib/action_dispatch/middleware/static.rb:127:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/railties-5.2.4.5/lib/rails/engine.rb:524:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/configuration.rb:227:in `call'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:706:in `handle_request'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:476:in `process_client'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/server.rb:334:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/puma-3.12.6/lib/puma/thread_pool.rb:135:in `block in spawn_thread'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
I, [2021-04-29T06:05:48.886582 #621-69840644155540] INFO -- : Completed 422 Unprocessable Entity in 1006ms (Views: 0.2ms | ActiveRecord: 0.2ms)
I, [2021-04-29T06:05:48.921563 #621-46975308830680] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:48 +0200
I, [2021-04-29T06:05:48.926434 #621-46975308830680] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:48.926508 #621-46975308830680] INFO -- : Parameters: {"data"=>{"event"=>"login"}}
I, [2021-04-29T06:05:48.930742 #621-46975308830680] INFO -- : client(8351907350) new client connection
I, [2021-04-29T06:05:48.932580 #621-46975308830680] INFO -- : Completed 200 OK in 6ms (Views: 0.2ms | ActiveRecord: 0.3ms)
I, [2021-04-29T06:05:48.963954 #621-46975308830680] INFO -- : Started POST "/api/v1/message_receive" for 37.201.138.73 at 2021-04-29 06:05:48 +0200
I, [2021-04-29T06:05:48.968192 #621-46975308830680] INFO -- : Processing by LongPollingController#message_receive as JSON
I, [2021-04-29T06:05:48.968270 #621-46975308830680] INFO -- : Parameters: {"client_id"=>"8351907350"}
I, [2021-04-29T06:05:49.975414 #621-46975308830680] INFO -- : Completed 200 OK in 1007ms (Views: 0.2ms | ActiveRecord: 0.4ms)
I, [2021-04-29T06:05:50.012076 #621-46975308747400] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:50 +0200
I, [2021-04-29T06:05:50.018042 #621-46975308747400] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:50.018145 #621-46975308747400] INFO -- : Parameters: {"client_id"=>"8351907350", "data"=>{"event"=>"spool"}}
I, [2021-04-29T06:05:50.021928 #621-46975325617560] INFO -- : Started POST "/api/v1/message_receive" for 37.201.138.73 at 2021-04-29 06:05:50 +0200
I, [2021-04-29T06:05:50.029321 #621-46975325617560] INFO -- : Processing by LongPollingController#message_receive as JSON
I, [2021-04-29T06:05:50.029604 #621-46975325617560] INFO -- : Parameters: {"client_id"=>"8351907350"}
I, [2021-04-29T06:05:50.127318 #621-46975308747400] INFO -- : Completed 200 OK in 109ms (Views: 0.2ms | ActiveRecord: 3.0ms)
I, [2021-04-29T06:05:50.161458 #621-69840638571120] INFO -- : Started POST "/api/v1/message_send" for 37.201.138.73 at 2021-04-29 06:05:50 +0200
I, [2021-04-29T06:05:50.167380 #621-69840638571120] INFO -- : Processing by LongPollingController#message_send as JSON
I, [2021-04-29T06:05:50.167480 #621-69840638571120] INFO -- : Parameters: {"client_id"=>"8351907350", "data"=>{"event"=>"chat_status_agent"}}
I, [2021-04-29T06:05:50.175333 #621-69840638571120] INFO -- : Completed 200 OK in 8ms (Views: 0.2ms | ActiveRecord: 0.4ms)
I, [2021-04-29T06:05:50.248232 #16576-46973095222680] INFO -- : execute Import::OTRS.diff_worker (try_count 0)...
I, [2021-04-29T06:05:50.248728 #16576-46973095222680] INFO -- : ended Import::OTRS.diff_worker took: 0.010341076 seconds.
E, [2021-04-29T06:05:51.035805 #615-47079581710740] ERROR -- : #<JSON::ParserError: 783: unexpected token at ''>
E, [2021-04-29T06:05:51.036348 #621-46975325617560] ERROR -- : Invalid client_id in receive loop! (Exceptions::UnprocessableEntity)
Any idea what might be wrong or caused the scheduler to stop?
