- Used Zammad version: 3.3.x
- Operating system: Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
- Browser + version: any
Some background:
Yesterday I fiddled around with methods that work within rails console and tried them as variables within a scheduler’s e-mail notifications, e.g.
#{article.first / no such method}
#{article.last_customer_agent_article / no such method}
Later, I also tried something more complex—I can’t remember the exact variable, but I think it was something containing parentheses and apostrophes, like:
#{Ticket.find_by(number:'101234').articles.first
—which seems to have broken that particular scheduler job completely. A second scheduler job (clone from the first one without the bad syntax does indeed run:
Also, after editing the older job, the ‘planned for’ time will change in the UI—but it won’t execute and it will stay at that exact timestamp.
@MrGeneration Could you maybe explain how Scheduler works technically, and why it didn’t try to run again later? I’d love to understand it and contribute something to the documentation!
- Scheduler job should be run again after removing not working variables
- Ideally Zammad would do better error handling before running the job, i.e. maybe ignore the syntax errors and just throw an error in
production.log
E, [2020-03-04T19:12:06.670017 #27160-69883551029620] ERROR -- : execute Job.run (try_count 0) exited with a non standard-error #<SyntaxError: (erb):1: syntax error, unexpected tIDENTIFIER, expecting tSTRING_DEND
I, [2020-03-04T19:12:06.671689 #27160-46960850806260] INFO -- : Scheduler stopped.
- Scheduler stopped
- That particular job wouldn’t execute again (even though I removed the variable completely)
(Also, I’d love to understand the log file better—what exactly does #27160 refer to? PID?)
Thanks,
Ben
