- Used Zammad version: 2.8.x
- Used Zammad installation source: docker-compose
- Operating system: Debian stretch
- Browser + version: Chromium Version 71.0.3578.98 (Offizieller Build) Built on Ubuntu , running on Ubuntu 18.04 (64-Bit)
EDIT 2019-02-02: I’ve since figured out that Zammad already has a feature that mostly does what I want - the “pending reminder” state. I didn’t know about this back when I wrote this posting.
I’ve attempted to add a follow-up feature to our Zammad test instance. The intended workflow looks like this:
Our sales agents often close tickets e.g. after they’ve written a mail to the customer. But in some cases (e.g. when the sales agent has sent a sales quote) the agent wants the closed ticket to automatically re-open itself after a certain configurable time (days, weeks, maybe even months) so that he can reach out to customers that haven’t responded yet.
Our old ticket system Kayako had a “Follow-Up” feature for this purpose where you could say:
In [minutes/hours/days/weeks/months/specific date]: [numeric value, e.g. 4]
Set status = open
(plus some more possibilities, e.g. change department, owner, type, priority; add a note, post a reply or forward the ticket)
Most of these features we don’t really need; IMO it would be enough if we had a date field “Follow-up” where you could e.g. put 2018-02-01, and when this date is reached, Zammad re-opens the ticket. I’ve implemented it like this:
- Settings → Objects → Ticket: add a new attribute:
- Name:
followup
- Display:
Wiedervorlage
- Format: Date
- Allow future: yes
- Allow past: no
- Name:
- Settings → Scheduler: add a new scheduler:
- Name:
Wiedervorlage-Tickets wieder öffnen
- When should the job run: I just checked everything
- Conditions: [Wiedervorlage] [before (relative)] [1] [Minute(s)]
- Execute changes:
- State → open
- Wiedervorlage →
- Disable notifications: no
- Note:
Durch automatische Wiedervorlage wieder geöffnet.
- Name:
(I hope I’ve got the condition right, before and after (relative) somehow are very confusing to me)
Generally, this seems to do what I expect. When I set the follow-up field of a ticket to a date in the past (e.g. 2019-01-01) to simulate a ticket that has reached it’s follow-up date, the scheduler lists this ticket in it’s preview and will also re-open it after 10 minutes.
- Side note 1: why can’t I manually run schedulers? Waiting makes it annoying to test.
- Side note 2: why does Zammad even allow me to set the field to a date in the past, when the field has Allow past: no?
But no note is added to the ticket. Nothing about a note in the ticket history either:
Martin von Wittich - 40 minutes ago
- updated Ticket followup ‘2019-01-15’
- 26 minutes ago
- notification sent to ‘martin.von.wittich@example.com(update:online)’
Am I misinterpreting the purpose of the note field? Is it to describe the scheduler? There doesn’t seem to be an Action to add a note (I see only a Delete Action).
The documentation seems to imply that this note should be added to the ticket: Scheduler — Zammad Admin Documentation documentation
- Insert a note to the ticket so that everyone can see what has happened in the ticket (only agents can read the note)
Is it bugged for anyone else?
- Create a scheduler and put some text into the note field.
Not sure if the other steps are needed, but I’ve documented everything above just in case.
