Hi there,
I am looking at Zammad for a friend of mine as a possible solution for their small company (which is growing). One of the things that came up is can information from an external CMDB / Asset Management system be bought into Zammad.
The idea is that when a user puts in a ticket all the assets scanned to that person can be displayed in the ticket.
Ideal for the technician to not have to bounce between two systems when a user just says “I have a problem with my machine” and also just as a quick double check when dealing with a customer that they do in fact have the correct assets scanned to them.
However, this has clear down sides because Zammad technically doesn’t come with an own asset management. This means the user can have one device only or would require a shitload of objects.
