Hello
I am on Zammad 3.1.x
I am using an RTL language, But knowledge base show in LTR.
Also how could i change default font of knowledge base via custom css directory ? I need it to be upgrade safe.
Regards
RTL in knowledge base
At the moment you can’t, but we have it on our list:
Might also (slightly) covered by:
@mehrshid
As a temporary solution, you can add in:
/opt/zammad/app/views/layouts/knowledge_base.html.erb
<html dir="rtl">
Thank you for your advise
