- Used Zammad version: 2.9.x
- Used Zammad installation source: Zammad install via DEB
- Operating system: Linux Debian 9.x
- After a server restart, Zammad should function properly.
Note: I moved the Postgresql database to an NFS drive to run the database directly on a new one if the server fails.
Everything works perfectly until the moment I restart the VM.
Zammad then has problems loading certain things.
Restarting the postgresql service solves the problem. Do you have an idea to solve the problem without restarting the service every time ? Of course there are only 3 words each time after restarting the VM.
You could solve this with the fstab and a script to restart the postgresql service but are there any other solutions ?
Apr 15 13:52:30 srvvzammad001 zammad-websocket-1.service[1268]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/applicat Apr 15 13:52:30 srvvzammad001 zammad-websocket-1.service[1268]: /opt/zammad/config/environment.rb:5:in `<top (required)>' Apr 15 13:52:30 srvvzammad001 zammad-websocket-1.service[1268]: script/websocket-server.rb:14:in `require' Apr 15 13:52:30 srvvzammad001 zammad-websocket-1.service[1268]: script/websocket-server.rb:14:in `<top (required)>' Apr 15 13:52:30 srvvzammad001 systemd[1]: zammad-worker-1.service: Service hold-off time over, scheduling restart. Apr 15 13:52:30 srvvzammad001 systemd[1]: Stopped zammad-worker-1.service. Apr 15 13:52:30 srvvzammad001 systemd[1]: Started zammad-worker-1.service. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: => Booting Puma Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: => Rails 5.1.6.2 application starting in production Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: => Run `rails server -h` for more startup options Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: Exiting Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: bundler: failed to load command: script/rails (script/rails) Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: PG::ConnectionBad: could not connect to server: No such file or directory Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: #011Is the server running locally and accepting Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: #011connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"? Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `initialize' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `new' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/pg-0.21.0/lib/pg.rb:56:in `connect' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/codapter.rb:697:in `connect' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/codapter.rb:221:in `initialize' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/codapter.rb:38:in `new' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/codapter.rb:38:in `postgresql_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:759:in `new_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:803:in `checkout_new_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:782:in `try_to_checkout_new_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:743:in `acquire_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:500:in `checkout' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:374:in `connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/conection_pool.rb:931:in `retrieve_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/coetrieve_connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.6.2/lib/active_record/connection' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/config/initializers/db_preferences_postgresql.rb:14:in `<top (required) Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/ Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/in load' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/ependency' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/ Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/engine.rb:655:alizer' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/ument' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/engine.rb:654: Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/engine.rb:612::Engine>' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/engine.rb:611: Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/engine.rb:611: Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable.izers' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:228:in `block in tsort_each' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:350:in `block (2 levels) in ent' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:422:in `block (2 levels) in ent_from' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:431:in `each_strongly_connect Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:421:in `block in each_strongl Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:415:in `call' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:415:in `each_strongly_connect Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:349:in `block in each_strongl Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in `each' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in `call' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:347:in `each_strongly_connect Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:226:in `tsort_each' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/ruby-2.4.4/lib/ruby/2.4.0/tsort.rb:205:in `tsort_each' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/initializable. Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/application.rb Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/config/environment.rb:5:in `<top (required)>' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/e' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/in require' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/ependency' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.6.2/lib/active_support/e' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: config.ru:3:in `block in <main>' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/builder.rb:55:in `ins Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/builder.rb:55:in `ini Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: config.ru:in `new' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: config.ru:in `<main>' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/builder.rb:49:in `eva Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/builder.rb:49:in `new Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/builder.rb:40:in `par Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/server.rb:319:in `bui' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/server.rb:219:in `app Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands/serve' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/server.rb:354:in `wra Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rack-2.0.6/lib/rack/server.rb:283:in `sta Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands/servert' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands/serveock in perform' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands/servep' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands/serverform' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor/command.rb:27:in `ru Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor/invocation.rb:126:in Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/thor-0.20.3/lib/thor.rb:387:in `dispatch' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/command/base.r Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/command.rb:44: Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: /opt/zammad/vendor/bundle/ruby/2.4.0/gems/railties-5.1.6.2/lib/rails/commands.rb:16 Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: script/rails:6:in `require' Apr 15 13:52:31 srvvzammad001 zammad-web-1.service[1242]: script/rails:6:in `<top (required)>' Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-websocket-1.service: Main process exited, code=exited, status=1/FAILURE Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-websocket-1.service: Unit entered failed state. Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-websocket-1.service: Failed with result 'exit-code'. Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-web-1.service: Main process exited, code=exited, status=1/FAILURE Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-web-1.service: Unit entered failed state. Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-web-1.service: Failed with result 'exit-code'. Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-websocket-1.service: Service hold-off time over, scheduling restart. Apr 15 13:52:31 srvvzammad001 systemd[1]: zammad-web-1.service: Service hold-off time over, scheduling restart. Apr 15 13:52:31 srvvzammad001 systemd[1]: Stopped zammad-web-1.service. Apr 15 13:52:31 srvvzammad001 systemd[1]: Started zammad-web-1.service. Apr 15 13:52:31 srvvzammad001 systemd[1]: Stopped zammad-websocket-1.service. Apr 15 13:52:31 srvvzammad001 systemd[1]: Started zammad-websocket-1.service.
- Install Zamamd on a new Debian VM
- Move the postgresql dircetory to a NFS Share
- Edit the /etc/postgresql/9.6/main/postgresql.conf to youre new directory
- Edit the /etc/fstab for atuo mounting the new NFS Share
- Reboot the VM
