Mailbox which was connected to the Zammad for sending notifications has been down sometimes and notifications were not sent. For now i have ~ 3K undelivered notifications. Tell me please, how i can resend notifications again for these mails?
Possibly Zammad have option for mail which can be reset from the rails console?
First of all: Please use the provided template and do not remove needed information.
Secondly: If those notification jobs are still there then you can resend them, if not, no chance.
What does the following say within zammad run rails c?
@MrGeneration, sorry for this, I thought that the template is not needed because Zammad work perfectly. My question about possible tips for solution with Zammad but not his fault.
Unfortunately not. I think it would be possible somehow but I’d need to investigate that for about an hour or more and that’s no time I currently can spare sorry.
